Ford Ranger TIM Controller
The new ECU for the Ford Ranger TIM (traction inverter module) is based on the openinverter design. It uses the original TIM's power eletronics, IGBT drivers, current sensors and voltage sensors.
So most of the information for the openinverter V2 board is also relevant for the Ranger inverter.
Just started to make the "Ranger TIM" Wiki, so most of the information is at the openinverter forum Ford Ranger section
Schematics and connector pinout
joromy_tim_w_GND_fill_15b - Schematic.pdf
Name (New TIM) | Circuit (Old TIM) | Function (New TIM) | |
1 | NC | NC | |
2 | MTMP- | 3708 (BN) Motor Temp sensor | Motor Temp sensor Input - |
3 | DIS_DRV | 3404 (YE) Chg cord plugged in | Charge cable plugged in (12V, Motor PWM inhibit when low) |
4 | USART_TX | 3017 (DG/WH) SIADIS RXD | Serial comm. Or WiFi module |
5 | CAN_H | 914 (TN/OG) J1850 bus plus | CAN BUS |
6 | STOP_RLY | 3235 (YE/LG) Stop lamp RLY | Stop signal when regen (Active, GND. Inactive, Z) |
7 | VSS_OUT | 679 (GY/BK) Vehicle speed signal | Vehicle Speed Signal, to IAA and Power steering (12v PWM) |
8 | SIG_MAIN_C | 3986 (DG) Main contactor | DC contactor and oil pump relay (Active, GND. Inactive, Z) |
9 | 12V_ALL_T | 276 (BN) Power hot all time | 12V all time (used for relay protection diode) |
10 | 12V_RUN_START | 640 (RD/YE) Power run/start | 12v in RUN, START, ACC |
11 | MTMP+ | 3757 (BK/WH) Motor Temp sensor | Motor Temp sensor Input + |
12 | NC | NC | |
13 | 3.3V_USART | 3018 (WH) SIADIS d/l | Serial comm. Or WiFi module |
14 | USART_RX | 3016 (LG/BK) SIADIS TXD | Serial comm. Or WiFi module |
15 | CAN_L | 915 (PK/LB) J1850 bus minus | CAN BUS |
16 | NC | NC | |
17 | NC | NC | |
18 | PRECHG_RLY | 3991 (TN) Precharge RLY contr | Precharge relay (Active, GND. Inactive, Z) |
19 | 12V_ALL_T | 276 (BN) Power hot all time | 12V all time (used for relay protection diode) |
20 | 12V_RUN_START | 640 (RD/YE) Power run/start | 12v in RUN, START (this will power up the inverter ECU) |
21 | NC | NC | |
22 | NC | NC | |
23 | GND_USART | 3019 (GY/BK) SIADIS GND | Serial comm. Or WiFi module |
24 | NC | NC | |
25 | NC | NC | |
26 | SIG_VSS_B | 3701 (DB/WH) VSS B signal | Encoder channel B |
27 | NC | NC | |
28 | NC | NC | |
29 | GND | 3233 (BK/LB) GND | GND |
30 | 5V_VSS | 3707 (OG) VSS +12 ref | Encoder PWR +5V |
31 | CH_GND | 57 (BK) Chassis GND | Chassis GND |
32 | NC | NC | |
33 | NC | NC | |
34 | NC | NC | |
35 | EMCY_PWR | 3997 (DG) Emergency PWR Off | EPO Emergency Power Off (Active, Z. Inactive, 12V) |
36 | SIG_VSS_A | 3700 (LB/RD) VSS A signal | Encoder channel A |
37 | OIL_P_RLY | 3005 (VT/LG) Oil pump RLY | DC contactor and oil pump relay (Active, GND. Inactive, Z) |
38 | NC | NC | |
39 | GND | 3233 (BK/LB) GND | GND |
40 | GND_VSS | 3659 (BK/PK) VSS GND | Encoder GND |
1 | NC | 224 (TN/WH) ABS fault in | ABS_FAULT (Active, GND. Inactive, 12V) |
2 | NC | NC | |
3 | GND_APS1 | 3837 (GY/YE) APS1 GND | Trottle pot GND |
4 | SIG_APS1 | 3835 (YE/WH) APS1 Signal | Trottle pot signal |
5 | 5V_APS1 | 3836 (YE/LB) APS1 +5V | Trottle pot PWR |
6 | ABS_ACT_IN | 491 (OG/LB) ABS active in | ABS input. Limit torque and regen. (Active, 12V. Inactive, GND) |
7 | GND_DIR_SW | 3500 (RD) DTR TR1 Signal | Gear switch GND |
8 | SW_START | 33 (WH/PK) PWR (Hot in start) | Key in start pos (Active, 12V) |
9 | SW_CRUISE | 3011 (BK/OG) APS2 GND | Cruise control switch/button (Active, 12V) |
10 | SIG_PWR_L | 3012 (WH) APS2 Signal | BMS input. Limit torque and regen. (Active, 12V. Inactive, Z) |
11 | SIG_OIL_PS | 3010 (TN) APS2 +5V | Analog/lamp oil P indicator (0-5V/Active, GND. Inactive, Z) |
12 | OIL_P_SENS | 3605 DB/WH) Oil P switch | Analog/switch oil P sensor (0-5V/Active, GND. Inactive, Z) |
13 | NC | 3503 (YE) DTR TR4 Signal | Goes to DTR switch and "old" BCM C1987 pin 18 |
14 | SW_BRAKE | 810 (RD/LG) Brake pedal sw | Brake pedal switch (Active, 12V) |
15 | NC | 3014 (BK/WH) APS3 GND | Spare wire |
16 | 5V_OIL_PS | 3015 (WH/RD) APS3 Signal | Only if analog 5V oil pressure sensor is used |
17 | ERROR_OUT | 3013 (GY/BK) APS3 +5V | Error output (open collector 0.5A) |
18 | SW_REV | 3502 (DG) DTR TR3A Signal | Cut at DTR switch pin3 and tie to pin11 140 (BK/PK) |
19 | NC | NC | |
20 | NC | 3501 (DB) DTR TR2 Signal | Goes to DTR switch and "old" BCM C1987 pin 17 |
21 | GND_BRK_PS | 3601 (WH/RD) Brake P sens | Brake pressure sensor GND |
22 | PS_BRAKE | 3600 (RD/WH) Brake P sens | Brake pressure sensor signal ~ 0.5-5V |
23 | 5V_BRK_PS | 3603 (RD) Brake P sens | Brake pressure sensor PWR |
24 | SW_FWD | 3504 (BK/OG) DTR GND | Gear switch (Active, Z. Inactive, GND) |
Modifications to original wiring
MODIFICATIONS: (Please read the Ford Ranger treads, for details)
- Replace temp sensor in inverter
- Reuse old connector in inverter ECU
- One new wire, from backup light to inverter.
- Cut old J1850 bus, and connect to CAN bus
- Cut some wires going to accelerator pot, connect to BMS, cruise switch, oil sensor and display.
- Cut one wire going to the gear shift switch, use for 5V to the oil pressure sensor.
- Remove two fault lamps, or reconnect to BMS.
