VW Touran Conversion
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
Pin # | Color code | Function |
1 | green/white | 5V |
2 | yellow/green | 5V |
3 | brown/blue | GND |
4 | white/blue | Throttle 1 0.75V-4.1V |
5 | green/blue | GND |
6 | blue/black | Throttle 2 0.38-2.05V |
ECU connector
11 | - | Throttle GND (Pin 5) |
12 | Throttle 2 out (Pin 6) | |
13 | Throttle 5V (Pin 1) | |
33 | Throttle GND (Pin 3) | |
34 | Throttle 1 out (Pin 4) | |
35 | Throttle 5V (Pin 2) | |
31 | Vacuum sensor GND | |
37 | Vacuum sensor 5V | |
83 | Vaccum sensor signal | |
86 | Ignition On? | |
87 | While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU | |
67 | CANL | |
68 | CANH |
Power steering
CAN bus
COB Id | Len | Function | Notes |
0x380 | Byte 2: 0-0xFE throttle position | Produced by ECU, so n/a when removed | |
0x1A0 | 1 | Byte 1, Bit 3: Brake pedal switch | Produced by whoever |
0x280 | Bytes 2 and 3: RPM*4 | Produced by you, Controls the rpm gauge | |
0x480 | 8 | Byte 6, Bit 2: Cruise light, Byte 1, Bit 3: EPC, Bit 4: engine | Controls various indicator lights |
0x288 | Byte 1: Temp Gauge 0.75x temp - 48 | Produced by you, Controls temp gauge | |
0x38A | Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+ | ||
0x572 | Byte 0, Bit 3: Key switch in start position |
Faults
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate.
Update on oil level warning: I fitted a 1k2 Ohm resistor from pin 2 to pin 3 (generates 2.5V "oil level") and the warning is gone.
Update 2: no it's not gone, it's a bit more complex. Read https://wak-tt.com/guides/ttc.pdf page 84. Maybe I can tell the dash panel to ignore the sensor.
Update 3: successfully programmed the instrument cluster to ignore the missing sensor. You need a CAN OBD adapter with matching software. Then in adaptation channel 39 change value to 0 (=sensor not present). Found here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Instrument_Cluster
