VW A/C Compressor
This type of compressor has been widely used in Volkswagen and Audi hybrid vehicles and can be found cheaply.
3d Scan: https://grabcad.com/
Part Numbers, Revisions and Refrigerant
The vehicle, date and refrigerant options have been scavenged from type stickers on compressors in ebay auctions. The list is not complete but supposed to give an overview.
Overview of A/C Compressors used
Part Number HW & SW Revision [1] Vehicles Years Refrigerant
12E820803x
12E820803B HW 4 - SW 4 VW e-Golf VII, VW e-Up 05.2014, R134a
12E820803C HW 4 - SW 7 Audi A3 1.4 TFSI e-tron 12.2013, 03.2014 R134a
12E820803D HW 5 - SW 4 Audi A3 1.4 TFSI e-tron
07.2015
07.2018
R134a
R134a, R1234yf
12E820803E HW 2 - SW 5 Audi A3 1.4 TFST e-tron
VW Passat B8 GTE
03.2015, 09.2015
06.2016
R134a
R134a, R1234yf
5QE816803x
5QE816803 HW 2 - SW 7 Audi A3 1.4 TFSI e-tron
VW Golf VII GTE
VW Passat B8 GTE
03.2015, 11.2015
08.2016, 08.2017
R134a
R134a, R1234yf
5QE816803A HW 3 - SW 9
5QE816803C HW 2 - SW 6 01.2018 R134a, R1234yf
5QE816803D HW 2 - SW 8
5QE816803F HW 2 - SW 7 07.2018 R134a, R1234yf
5QE816803H HW 3 - SW 9 VW Passat B8 GTE 01.2016 R134a
Generally the switch to R1234yf compatibility was around Juni 2016. The oil used for all compressors is 120ml PAG SP-A2.
LIN Bus Communication
The baud rate of the LIN bus is 19200 baud.[2]
Control and Answer Messages to/from the Compressor [3]
ID Description Length Checksum Type Byte 0 Byte 1 Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7
31 (0x61) Answer from the compressor 8 Enhanced HV OK:
0 for V < 200V
1 for V > 200V
always 112 RPM set from command 110 for V<200V,
14 for V>200V, AC not running,
46 for V>200V, AC running
? Temperature:
160 at 24°C,
Scaling unknown
54 at 109V, 28 at 56V 83 at 166V
scaling: Voltage/2
32 (0x20) Command to the compressor 6 Enhanced RPM (decimal from 20-250) Bit 0: Start, Bit 2: Activate 0 0 0 0
Electrical Connection[4]
connectors are:
HVA 280 KEY_D from TE +HV left side (near to the 12V conn.), -HV right side (far from the 12V conn)
1J0973714 8= +12V , 5= GND, 2= LIN
