The Mitsubishi Outlander had an optional fitment of a 100/110/220V (Market dependent) ac outlet for the use of low power appliances.
This unit is labelled as part number 37129-01001
Warning - this information is not verified, just an observation at this stage! Ensure you make your own judgements regarding the connection of this unit!
Connection
Label
Mitsubishi Connector Number
Comments
HV DC Connections
D-217-1 P
Ring Terminal connections labelled as + and -, appear to be designed to connect to ring terminal outlets from Power Distribution unit
HV DC Connections
D-217-1 N
AC outlet
D-216 AC1
Ring terminal connection labelled as + appears to be AC Outlet connection, cannot determine where Neutral/Negative connection is
AC outlet
Not found
Cannot identify the Negative connection for AC power
LV Connections
1
No Definitive description, does not appear to match the Outlander Wiring diagram from 2017 or 2019
LV Connections
2
LV Connections
3
LV Connections
4
