I'm just starting a project. I have a 1930 Model A ford that I'm converting to Electric.
I have a M3 980 motor and subframe just about ready to assemble. Im still looking into battery options. Any suggestions are more them welcome.
WIP 1930 ModelA Ford Coupe
- muehlpower
- Been thanked: 188 times
Re: 1930 ModelA Ford Coupe
Nice project. I also have a 1930 Ford. Yours appears to be a coupe. With the Mustang II front axle and the height of the frame, I assume it will be a full fender. Do you drive with a hood? Then you have enough space for the battery, and without a cardan shaft, there is also space for a few modules between the frame tubes. Do you have a seat or trunk in the back?
I will have fenders and a hood. I would like it to look as stock as possible. The car has a trunk in the back I would like to keep the weight as far back as I can with luck it will wheelie. I'm going to pick up the body in Florida next week and once I get it on the frame I will know more. I would love to see more pics of your car.
- Has thanked: 323 times
- Been thanked: 354 times
I'll just note that in my '40 Chevy, I have nearly all the weight in the rear, with a Sport LDU, and it trips an overcurrent safety before pulling the front wheels. It gets really light in the nose, but the instantaneous load/amp draw seems to make things unhappy. I'm working on the tune still so maybe in the future I'll find a way to get full power and no trips and resulting wheels up action, but at least so far, I'd say wheelies seem to be a bit of a challenge.
This begets the question, where are you located? I'm in Raleigh.
Re: WIP 1930 ModelA Ford Coupe
Here's some links.
Build thread: https://openinverter.org/forum/viewtopic.php?t=358
Youtube: https://www.youtube.com/@MangelsdorfSpeed
Instagram: https://www.instagram.com/paulsmangelsdorf/
I didn't do a great job with photos in the build thread, but there are a lot on Instagram. And I really only started the Youtube stuff when I was upgrading the car, but there's good stuff from Drag Week.
