Zombiverter not switching to charge mode with Leaf PDM
Has thanked: 206 times
Been thanked: 562 times
Re: Zombiverter not switching to charge mode with Leaf PDM
Kelju wrote: Mon Jan 20, 2025 4:31 pm charging power follows the request as expected.
Perfect :) please continue to do some testing and let me know if you can break it ;)
Kelju
Has thanked: 13 times
Been thanked: 18 times
Post by Kelju »
tom91 wrote: Mon Jan 20, 2025 4:51 pm Perfect :) please continue to do some testing and let me know if you can break it ;)
I think I found some sort of a bug...
During a long charging session, the charging power stops following the request intermittently, for a very long time and then at some point it starts following the request again. As this was a very long charging session, I was only able to catch the start of the issue and not the moment when it starts following the request again.
Here is the log file
20250209_Low_Charging.zip
(16.52 MiB) Downloaded 434 times
Kelju wrote: Mon Feb 10, 2025 6:13 pm Here is the log file
Just realised how large this file is. it is also without any time data.
Did you get a chance to look at the behaviour some more?
So it shows the drop in current when the commanded "charge power" in 0x1F2 changes. Which does not seem to corrolate as you would hope.
What were your params for the charge mainly your voltagespnt?
