Perfect
Zombiverter not switching to charge mode with Leaf PDM
- Has thanked: 330 times
- Been thanked: 848 times
Re: Zombiverter not switching to charge mode with Leaf PDM
Kelju
- Has thanked: 13 times
- Been thanked: 19 times
I think I found some sort of a bug...
During a long charging session, the charging power stops following the request intermittently, for a very long time and then at some point it starts following the request again. As this was a very long charging session, I was only able to catch the start of the issue and not the moment when it starts following the request again.
Here is the log file
Just realised how large this file is. it is also without any time data.
Did you get a chance to look at the behaviour some more?
So it shows the drop in current when the commanded "charge power" in 0x1F2 changes. Which does not seem to corrolate as you would hope.
What were your params for the charge mainly your voltagespnt?
