Nissan Leaf Powered E46 Touring
- Has thanked: 75 times
- Been thanked: 696 times
Another day, another EV project. This time we have a 2003 E46 touring formally powered by a mayonaise filled 2.2 petrol engine.
The plan :
Gen 1 Leaf motor
Lexus IS300h inverter
400v of LTO cells
The plan :
Gen 1 Leaf motor
400v of LTO cells
- Has thanked: 455 times
- Been thanked: 1771 times
Re: Nissan Leaf Powered E46 Touring
Wow, that was quick. Can you come over and do mine
Is it again aluminium leftovers and a jigsaw for the adapter plate?
zippy500
- Has thanked: 83 times
- Been thanked: 7 times
That looks really good
I have been emailing lots people about getting a leaf adaptor plate made only to be meet with silence.
Is that 25mm plate ? did you cut down the shafts on the motor or gearbox, On the EM57 the motor shaft looks like it sticks out over 50mm.
Yeah 25mm plate. Only had to cut the pilot bearing nose off the gearbox input shaft. about 8mm gap now.
Making adapter plates by hand is easy. Just a bit of work. I know everyone wants fancy cnc stuff these days but a jigsaw, drill press and some sweat gets its done just the same.
zippy500
Thats good nearly getting the confidence to start making it myself>
Will you youtube your adapter build, how will you couple it and get the shafts perfectly aligned.
Might need two plates for the EM57 motor as has a overhang on the motor.
Yes will be on youtube. In the mean time here is the video series I did on building the adapter for my E39 conversion back in 2013. Ran perfectly for 5 years despite dire predictions of doom from the internet :
zippy500
Thanks will take a look,
Just had a quote of $1400 for a plate and coupler
That would blow the budget on the 1000 euro build
Think I will take a chance and go ahead and get some aluminium plate.
.....right where is my jigsaw, was watching on YouTube how some guys are cutting 12mm plate with a circular saw with a wood blade
- Has thanked: 145 times
- Been thanked: 369 times
I cut my twin 15mm plate with hobby jigsaw back in 2013. Trick is to have WD40 ready to spray on the saw blade so it is allways lubricated. If not alu can stick to the saw blade and quickly ruin your blade.zippy500 wrote: ↑Mon Apr 15, 2019 1:33 pm Thanks will take a look,
Just had a quote of $1400 for a plate and couplerThat would blow the budget on the 1000 euro build
.....right where is my jigsaw, was watching on YouTube how some guys are cutting 12mm plate with a circular saw with a wood blade![]()
A
Forget $1400. I just did this in an afternoon because my brain was melted from learning fpga programming. Total cost about 100 Euros.
The lineup is easy. Sit the motor and gearbox vertically but only bolt one side. Motor or gearbox to the adapter plate. Then spin the motor slowly. any misalignment pushes the gearbox to the required position. The old guys did this with dc conversions back in the day. Only difference now is you need an inverter:)
zippy500
Excellent work,
What coupler did you use on leaf spline shaft ?
Going to have a measure up later I think
Fiat multipla 1.6 petrol clutch friction plate. I did a shrink fit of the coupler tube onto it to help tighten the splines on the leaf motor shaft.
zippy500
Many Thanks for all the useful info,
Can ask what do you mean by shrink fit, did you heat the coupler body fit the clutch part then let it cool ?
AAaahh, Fiat Multipla !! The deisgn classic out of the ordinary !!!!Jack Bauer wrote: ↑Mon Apr 15, 2019 5:55 pm Fiat multipla 1.6 petrol clutch friction plate. I did a shrink fit of the coupler tube onto it to help tighten the splines on the leaf motor shaft.
/Per
And it did work didnt itJack Bauer wrote: ↑Mon Apr 15, 2019 5:55 pm Fiat multipla 1.6 petrol clutch friction plate. I did a shrink fit of the coupler tube onto it to help tighten the splines on the leaf motor shaft.
Well the only issue may be that teeth profile are not right in the attitude. But tight clamping helps here also.
I still recommend Lovejoy style coupler between motor and transmission, due to the fact that some misalignment may still exist. Also that coupler is very good at absorbing impact force from motor torque.
zippy500
Think this a good idea, but one that will take good power is around 90mm length, going to need a thick adapter plate to hid this .
No need for that. I just put mine in a lathe and reduced depth from both sides appropriately so the joint came in the middle approximately. You still have to guarantee a good ammount of seat though. Note that i took more material from the transmission side since motor has longer shaft. https://mazdamx3ev.wordpress.com/2018/0 ... lopka-ven/
Those welds are just for ornament
zippy500
I forgot you have the depth of the inside of the bell housing .arber333 wrote: ↑Tue Apr 16, 2019 5:28 am
Those welds are just for ornamentSplines are kept in position by bolts and shrink-fit of material.
How do to stop the lovejoy coupler halves from sliding on the shafts and apart from each other ?
Might have to give the machining part to a shop, I don't have access to a lathe or machining skills
Yes i was fortunate enough that i had a long sleeve to support shaft in bell housing. To support transmission side coupler i used existing clutch bearing. I gave it a clearance of some 1mm or 2mm and supported in on the inside by another sleeve. I can hear it sometimes in the morning when shafts are cold. But later when everything heats up clearance is enough.zippy500 wrote: ↑Tue Apr 16, 2019 9:26 amI forgot you have the depth of the inside of the bell housing .arber333 wrote: ↑Tue Apr 16, 2019 5:28 am
On the motor side i used 3x allen bolts with spring washer to keep the coupler in place. It is not ideal, but i could make it on short notice. Ideally the best would be to cut the coupler on one side and machine clamping mechanism into coupler. When you torque it down there is no possibility of axial movement. This also applies to transmission side. See here... https://www.ktr.com/en/products/power-t ... ping-hubs/
Motor and gearbox mated up and tested. Time to get it back in the car.
zippy500
Thanks for the video , very helpful , was adapter plate tapped for the bolts ?
That's a nice simple solution to just put some weld on the shaft to stop the coupler moving
Back in the car and driveshaft hooked up.
Some more progress. Motor now mounted and have started mocking up the positioning of the Lexus inverter.
Very nice diy motor mounts.
what are you going to fill the empty space with?
