Hi all,
I’m working on an EV conversion on a bmw e46 i used is300h gearbox and inverter with zombieverter vcu it runs and drives with 2 mg zs battery modules around 48v for testing purposes and planning to use 16 MG ZS EV VDA355 battery modules
I’d like to hear from anyone who has experience with these modules about what bms can be used
Thanks in advance!
— [Kimet ]
MG ZS EV battery modules in a conversion?
- Has thanked: 265 times
- Been thanked: 720 times
Re: MG ZS EV battery modules in a conversion?
You have pictures of the modules you are using? Take of the plastic cover to check which version of modules you have.
One has BMS circuity and the other is a dumb module.
Hi Tom I got 2 mg zs battery packs 36 battery modules 18 black with bms master,
And 18 grey without bms slave modules
viewtopic.php?p=45051&hilit=LTC6813#p45051
viewtopic.php?p=71310&hilit=LTC6813#p71310
viewtopic.php?p=73334#p73334
viewtopic.php?p=78916#p78916 So the Thunderstruck MCUs work with the LTC6813 chip based monitoring https://www.thunderstruck-ev.com/mcu.html
- Has thanked: 461 times
- Been thanked: 1778 times
Moved to MG forum. Please put some thought into choosing a matching forum
