MG ZS EV battery modules in a conversion?
E46Kim
Post by E46Kim »
Hi all,
I’m working on an EV conversion on a bmw e46 i used is300h gearbox and inverter with zombieverter vcu it runs and drives with 2 mg zs battery modules around 48v for testing purposes and planning to use 16 MG ZS EV VDA355 battery modules
I’d like to hear from anyone who has experience with these modules about what bms can be used
Thanks in advance!
— [Kimet ]
Has thanked: 265 times
Been thanked: 720 times
Re: MG ZS EV battery modules in a conversion?
You have pictures of the modules you are using? Take of the plastic cover to check which version of modules you have.
One has BMS circuity and the other is a dumb module.
E46Kim
Post by E46Kim »
Hi Tom I got 2 mg zs battery packs 36 battery modules 18 black with bms master,
And 18 grey without bms slave modules
Has thanked: 461 times
Been thanked: 1778 times
Moved to MG forum. Please put some thought into choosing a matching forum
