Which board is better to use?
Hello. I have a task to create an electric buggy. I want to use the native battery and inverter from the nissan leaf 1 gen. I need a slow charging function from the native connector and about 50 kW of power on the engine. Which of the boards can use these functions? Please do not be angry, I am new to this forum and I use a translator to communicate with you. Thank you
- Has thanked: 76 times
- Been thanked: 218 times
Re: Which board is better to use?
Zombieverter board will work for that just fine. Plenty of documentation on here and the wiki as well for running a leaf setup.
