EVBMW Zombieverter Videos Table of Contents
Has thanked: 635 times
Been thanked: 1610 times
List of authentic Damien Maguire's Zombieverter Videos with some points of interest
Re: EVBMW Zombieverter Videos Table of Contents
RESOURCES:
Where to buy it?
EVBMW Webshop Where to get the firmware upgrade?
Mr. Damien Maguire's GitHub
Where to get more documentation?
OpenInverter Wiki
Where to get product support?
OpenInverter Forum: ZombieVerter VCU Support
Where to fuel the fire?
Mr. Damien Maguire's Patreon
PARTS
56 Pin Header (Male) - Part # 211PL562L0011
https://www.aliexpress.us/item/2255799870142865.html]
Sicma ECU Connector.pdf
(274.91 KiB) Downloaded 181 times
Who would luv to see this book?
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
I think you're writing it!
Working with High Voltage Safety Tips
Alibro
Has thanked: 507 times
Been thanked: 325 times
Post by Alibro »
Now I've finally joined the club I'm binge watching and reading everything Zombieverter related.
Has anyone found a cheap de-pinning tool for these connectors?
Asking for a friend who may have pushed in a red cable where he intended to push in a black cable. :?
Has thanked: 330 times
Been thanked: 848 times
Alibro wrote: Sat May 24, 2025 9:11 am Has anyone found a cheap de-pinning tool for these connectors?
Simple picks are fine just take off the connector cap the orange bit. The retention clips are quite big so a tiny screw driver or pick works in my experience.
Alibro wrote: Sat May 24, 2025 9:11 am Now I've finally joined the club I'm binge watching and reading everything Zombieverter related.
the top and bottom plastic retaining pins are very soft plastic and are easily damaged, the proper tool below works 50% of the time, if you hear a click when pressing it in, you have a chance on extracting the pin/wire
Alibro
Post by Alibro »
Thanks mate
I saw that tool for sale but didn't fancy paying for it so followed your bad example and de-pinned the offending sockets with a jewellers screwdriver.
It was way easier than I first thought it would be.
