how to charger testing
medo
Post by medo »
Hi, I'm converting from a gen2 charger to a gen3 and have the charger on the table here. Can I put the charger in run mode without a battery to see if it works? The external control unit is pinned and connected. If so, how?
Has thanked: 209 times
Been thanked: 577 times
Re: how to charger testing
Depending on what firmware you have on it and board, which you have not mentioned.
https://openinverter.org/wiki/Tesla_Mod ... 5_Software
Run it in "Manual" mode so you can see the values from the 3 phase modules populate in the spotvalues. Then you can move on to providing AC power and HV power.
medo
Post by medo »
Im running on 1.19, but i don´t know, how to run in manual Mode
edit:
I found it, when I press start inverter in manual mode, I get the error message
(Unknown command sequence)
medo
what is wrong here (Unknown command sequence)
Post by medo »
I get the same error message on both (Unknown command sequence ) VCU(2.22A) and Gen3 charger (1.19R) when I go to manual inverter start, but I can't figure out what the problem could be
Re: what is wrong here (Unknown command sequence)
They both do not support that function. As they both are not inverters.
medo
Post by medo »
but how can I start the charger in manual mode to check if all modules are working and whether values ​​are being transmitted
Has thanked: 382 times
Been thanked: 1575 times
Please don't open a new topic (with a meaningless title) for a little sub question.
Chose "inputype" Manual or Manual-3P and maybe set enablepol to ActiveLow to have all conditions out of the way
medo
Post by medo »
thank you very much Johu, that's it, must a battery be connected to see values ​​or is something wrong here
No reply from modules though... Do the leds on the modules light up?
medo
Post by medo »
Yes, the leds lights up
somehow should maybe edit the pin assignment, on the picture from damien even pin 4 is missing, maybe I swapped enable pin with activate pins,
I measured the 12-pin connector
Pin1 0V
pin2 12v
pin3 5v
pin4 1.3v
pn5 2.4v
pin6 5v
pin7 5v
pin8 5v
pin9 3.3v
pin10 3.3v
pin11 3.3v
pin12 0v
medo
Post by medo »
the pin assignment is correct, LEDs lights up, can messages also be sent from the control unit, but the modules do not respond,
What I also noticed is that module 1 and module 2 switch on at the same time, but module 3 switches two seconds later, and the same thing happens when switching off, module 1 and 2 switch off immediately, but module 3 switches two seconds later
medo
Post by medo »
I did another measurement, on the charger side between can high and low we have 118 ohms, between can high and ground 1.68 volts, also between can low and ground 1.68 volts
I'm not sure if I've connected everything correctly, it's not particularly clear in the wiki
is it like the picture right???
