Kia Niro BMS
evdc
Re: Kia Niro BMS
Post by evdc »
Thanks for the answer @bexander , but if you see here
0 3947 1 3952 2 3947 3 3950 4 3949 5 3952
Module: 0
All Cells to Balance
111111
Cell to Balance Filtered :101010
1 3 5  Voltage Diff Min-Max: 119
0 3952 1 3951 2 3947 3 3942 4 3943 5 3954
Module: 1
111111
0 3946 1 3954 2 3951 3 3952 4 3951 5 3952
Module: 2
111111
0 3948 1 3907 2 3949 3 3946 4 3940 5 3946
Module: 3
111111
0 3944 1 3949 2 3951 3 3952 4 3942 5 3948
Module: 4
111111
0 3946 1 3954 2 3949 3 3951 4 3949 5 3952
Module: 5
111111
0 3940 1 3944 2 3943 3 3951 4 3943 5 3944
Module: 6
111111
0 3944 1 3952 2 3951 3 3868 4 3944 5 3947
Module: 7
110111
Cell to Balance Filtered :100010
1 5  Voltage Diff Min-Max: 119
0 3948 1 3946 2 3943 3 3947 4 3949 5 3952
Module: 8
111111
0 3943 1 3954 2 3947 3 3953 4 3945 5 3944
Module: 9
111111
0 3947 1 3941 2 3938 3 3987 4 3946 5 3952
Module: 10
111111
0 3947 1 3952 2 3945 3 3948 4 3946 5 3953
Module: 11
111111
0 3943 1 3943 2 3940 3 3945 4 3939 5 3944
Module: 12
111111
0 3948 1 3946 2 3937 3 3949 4 3947 5 3950
Module: 13
111111
0 3944 1 3955 2 3938 3 3951 4 3950 5 3950
Module: 14
111111
0 3945 1 3945 2 3941 3 3945 4 3945 5 3948
Module: 15
111111
0 3941 1 3951 2 3939 3 3952 4 3944 5 3943
Module: 16
111111
0 3947 1 3948 2 3942 3 3942 4 3939 5 3948
Module: 17
111111
, the balance is included for the 1st, 3rd and 5th cells for all modules except for the 7th module, which is correctly written on serial.out, however, in practice it starts the balance of the 3rd cell can be noticed here
High Cell: 3985V Module: 10 Cell: 3  Low Cell: 3852V Module: 7 Cell: 3
Total Voltage: 425932
High Cell Temp C: 14  Low Cell Temp C: 12  High Die Temp C: 20
because when the balance of the 3rd cell in the 7th module is not released
0 3949 1 3953 2 3948 3 3950 4 3950 5 3952
Module: 0
111111
0 2 4  Voltage Diff Min-Max: 122
0 3951 1 3954 2 3947 3 3943 4 3943 5 3954
Module: 1
111111
0 3946 1 3954 2 3949 3 3954 4 3949 5 3952
Module: 2
111111
0 3947 1 3907 2 3949 3 3945 4 3941 5 3947
Module: 3
111111
0 3944 1 3953 2 3952 3 3951 4 3943 5 3947
Module: 4
111111
0 3944 1 3952 2 3948 3 3953 4 3951 5 3950
Module: 5
111111
0 3941 1 3944 2 3943 3 3952 4 3941 5 3940
Module: 6
111111
0 3946 1 3953 2 3950 3 3865 4 3943 5 3947
Module: 7
110111
0 3947 1 3944 2 3940 3 3947 4 3947 5 3951
Module: 8
111111
0 3943 1 3954 2 3946 3 3954 4 3946 5 3944
Module: 9
111111
0 3947 1 3940 2 3940 3 3987 4 3946 5 3949
Module: 10
111111
0 3950 1 3952 2 3944 3 3951 4 3946 5 3954
Module: 11
111111
0 3942 1 3946 2 3939 3 3946 4 3935 5 3946
Module: 12
111111
0 3946 1 3946 2 3937 3 3949 4 3946 5 3948
Module: 13
111111
0 3942 1 3955 2 3941 3 3951 4 3947 5 3949
Module: 14
111111
0 3947 1 3944 2 3940 3 3944 4 3946 5 3947
Module: 15
111111
0 3940 1 3950 2 3940 3 3953 4 3945 5 3942
Module: 16
111111
0 3945 1 3951 2 3941 3 3943 4 3935 5 3945
Module: 17
111111
the voltage is like this
High Cell: 4002V Module: 10 Cell: 3  Low Cell: 3881V Module: 7 Cell: 3
Total Voltage: 426104
Best Regards
bexander
Has thanked: 78 times
Been thanked: 102 times
Re: Kia Niro BMS
Post by bexander »
When cell balancing is active you can not trust the cell voltage readings. When a cell is balanced it will have effect on adjecent cell voltage readings. To measure the cell voltages correctly, no balancing can be active while taking measurement.
An example from an old log.
Voltage reading at rest (no balancing):
1: 4136 4144 4142 4143 4142 4141 4143 4142
Balancing active as follows:
1: 0010 0101
Voltage reading with active balancing:
1: 4136 4153 4121 4154 4150 4125 4159 4124
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Thu Oct 24, 2024 3:08 pm When cell balancing is active you can not trust the cell voltage readings. When a cell is balanced it will have effect on adjecent cell voltage readings. To measure the cell voltages correctly, no balancing can be active while taking measurement.
1: 0010 0101
Ok, but why when I turn off the balancing of the 7th module completely I keep seeing how the 3rd cell discharges? I also charged and discharged the battery for a week and the balance only got worse!
Best regards
manny
Has thanked: 58 times
Been thanked: 159 times
Re: Kia Niro BMS
Post by manny »
if one cell always discharging. I would look for a hardware problem.
first check the cell voltage with a multimeter. and compare them with the bms readings.
if without the bms connected the battery still discharges.
maybe the cell is bad or the bms chip is damaged and the balance is always on?
  • PSA battery (50kWh)
  • Zombie VCU
evdc
Re: Kia Niro BMS
Post by evdc »
manny wrote: Thu Oct 24, 2024 5:12 pm if one cell always discharging. I would look for a hardware problem.
I did the following test, when I ran a balance on all modules up to and including the 7th, there was no problem and it didn't include the balance on the 3rd cell, however when I ran a balance on all the modules up to 8 then it ran the balance on the 3rd cell from my 7th module even though it didn't was included in the balance command being sent. I think it triggered the balance of all modules from 1st to 7th the same way it did for my 8th module! Check if I address the modules correctly and there was no problem there, I really don't know how to solve this problem.
Best Regards
bexander
Re: Kia Niro BMS
Post by bexander »
Have you tried swapping position of the different modules? Do you still have the same effect when having module 7 as module 1 or as module 12?
Test with this SW and all modules. Do you still have the same behaviour?
BMS_test_OI.ino
(45.27 KiB) Downloaded 737 times
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Fri Oct 25, 2024 1:03 am Have you tried swapping position of the different modules? Do you still have the same effect when having module 7 as module 1 or as module 12?
BMS_test_OI.ino
Hello, after I set my pin out to the code they sent me, I got the serial out, I don't know why.
Best Regards
Entering Configuration Mode Failure...
InitCAN WD timeout
Daisy chain init
UARTSlaveDevicesWakeUp WD timeout
Set all slaves
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
WRITEALL fail
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
WRITEALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
A
errorByte cleared
Error FF
A
errorByte cleared
READALL fail
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
Error FF
E
errorByte cleared
WRITEALL fail
STATUS cleared
E
errorByte cleared
Error FF
Error FF
���O~��Error FF
A
errorByte cleared
READALL fail
BMS_test_OI.zip
(9.88 KiB) Downloaded 668 times
bexander
Re: Kia Niro BMS
Post by bexander »
The CAN init fails. The SPI-bus setup is done by CAN init, hence the MAX17841 init fails as well.
I suggest you start by looking at why the CAN-init fails.
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Sat Oct 26, 2024 12:31 pm The CAN init fails. The SPI-bus setup is done by CAN init, hence the MAX17841 init fails as well.
Can I not use CAN to run this program?
bexander
Re: Kia Niro BMS
Post by bexander »
No need to use CAN but you then need to setup the SPI-bus in another way.
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Sat Oct 26, 2024 2:06 pm No need to use CAN but you then need to setup the SPI-bus in another way.
Hello, I was able to run the test code that you sent me and I compared the series output of the two codes and I think I understood what the main error is.
Output from testCode:
InitCAN WD timeout
Daisy chain init
Set all slaves
3 2 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 0 80 20 D D3
422.8   0.0     0.0     8
48 3920 83 3772
-18     79      -18     15
1: 3879 3918 3917 3919 3919 3918 79 -18 14
2: 3918 3916 3919 3917 3918 3918 -18 79 13
3: 3916 3918 3918 3916 3918 3919 79 -18 14
4: 3918 3918 3918 3918 3919 3919 -18 79 15
5: 3916 3916 3918 3916 3884 3917 79 -18 14
6: 3917 3919 3919 3918 3918 3919 -18 79 14
7: 3919 3919 3919 3916 3899 3917 79 -18 13
8: 3918 3919 3918 3919 3918 3920 -18 79 14
9: 3918 3918 3911 3919 3918 3919 79 -18 14
10: 3917 3919 3919 3914 3917 3919 -18 79 14
11: 3918 3919 3919 3919 3919 3919 79 -18 14
12: 3918 3917 3911 3919 3917 3919 -18 79 14
13: 3919 3919 3918 3918 3917 3920 79 -18 14
14: 3918 3916 3918 3919 3772 3918 -18 79 14
15: 3917 3919 3917 3919 3917 3919 79 -18 14
16: 3918 3919 3919 3917 3918 3918 -18 79 14
17: 3917 3919 3919 3918 3916 3918 79 -18 14
18: 3916 3920 3917 3917 3920 3880 -18 79 14
422.8   0.0     0.0     8
48 3920 83 3772
-18     79      -18     15
2: 3918 3916 3919 3918 3918 3918 -18 79 14
3: 3917 3918 3918 3914 3918 3919 79 -18 14
4: 3919 3918 3917 3918 3919 3919 -18 79 15
5: 3916 3916 3918 3916 3883 3917 79 -18 14
6: 3917 3919 3919 3919 3918 3919 -18 79 14
7: 3918 3919 3919 3916 3899 3918 79 -18 13
9: 3918 3919 3911 3918 3918 3919 79 -18 15
10: 3917 3918 3919 3915 3917 3919 -18 79 14
11: 3918 3919 3919 3919 3920 3919 79 -18 14
12: 3919 3918 3911 3919 3917 3919 -18 79 14
13: 3919 3919 3918 3919 3917 3920 79 -18 15
14: 3918 3916 3918 3918 3772 3919 -18 79 14
15: 3918 3919 3917 3919 3917 3919 79 -18 14
17: 3918 3919 3919 3917 3915 3918 79 -18 14
18: 3916 3920 3917 3918 3920 3880 -18 79 14
422.8   0.0     0.0     8
48 3920 83 3772
Output from other code i run:
UARTSlaveDevicesWakeUp done 1
UARTSlaveDevicesWakeUp done 2
Modules:18
all slaves balance off
Balance cells
High Cell: 3922V Module: 0 Cell: 1  Low Cell: 3774V Module: 4 Cell: 4
Total Voltage: 422901
High Cell Temp C: 11  Low Cell Temp C: 0  High Die Temp C: 15
Low Temperature Restriction
Power Control: 29
Regen Control: 29
Status: 1000   Charger LED Status: 10
0 3918 1 3922 2 3916 3 3918 4 3922 5 3880
Module: 0
111111
0 2 4  Voltage Diff Min-Max: 150
0 3918 1 3919 2 3918 3 3918 4 3915 5 3919
Module: 1
111111
0 3918 1 3921 2 3918 3 3918 4 3919 5 3921
Module: 2
111111
0 3918 1 3919 2 3918 3 3919 4 3916 5 3921
Module: 3
111111
0 3918 1 3919 2 3920 3 3919 4 3772 5 3918
Module: 4
101111
0 2  Voltage Diff Min-Max: 150
0 3919 1 3920 2 3917 3 3919 4 3918 5 3921
Module: 5
111111
0 3918 1 3915 2 3910 3 3919 4 3916 5 3918
Module: 6
111111
0 3919 1 3918 2 3920 3 3919 4 3920 5 3917
Module: 7
111111
0 3917 1 3921 2 3919 3 3914 4 3917 5 3919
Module: 8
111111
0 3919 1 3919 2 3910 3 3918 4 3916 5 3921
Module: 9
111111
0 3919 1 3919 2 3918 3 3919 4 3918 5 3919
Module: 10
111111
0 3921 1 3920 2 3921 3 3915 4 3897 5 3916
Module: 11
111111
0 3917 1 3918 2 3919 3 3918 4 3918 5 3920
Module: 12
111111
0 3916 1 3916 2 3918 3 3915 4 3885 5 3918
Module: 13
111111
0 3918 1 3916 2 3919 3 3918 4 3918 5 3918
Module: 14
111111
0 3916 1 3919 2 3918 3 3915 4 3917 5 3918
Module: 15
111111
0 3918 1 3915 2 3921 3 3917 4 3919 5 3916
Module: 16
111111
0 3879 1 3918 2 3915 3 3919 4 3919 5 3919
Module: 17
111111
High Cell: 3922V Module: 0 Cell: 1  Low Cell: 3772V Module: 4 Cell: 4
Total Voltage: 422873
High Cell Temp C: 11  Low Cell Temp C: 8  High Die Temp C: 15
Power Control: 88
Regen Control: 88
High Cell: 3937V Module: 1 Cell: 3  Low Cell: 3756V Module: 4 Cell: 4
Total Voltage: 422808
High Cell Temp C: 11  Low Cell Temp C: 8  High Die Temp C: 16
bexander
Re: Kia Niro BMS
Post by bexander »
evdc wrote: Sat Oct 26, 2024 4:27 pm Hello, I was able to run the test code that you sent me and I compared the series output of the two codes and I think I understood what the main error is.
That sounds great. Please, share what the error was so I and others can learn from it.
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Sun Oct 27, 2024 11:44 am That sounds great. Please, share what the error was so I and others can learn from it.
I haven't solved the problem yet, but I noticed that the lowest cell in the code you sent me is in 14 modules, and in the code I'm using, the lowest cell is in the 5th module and I think that the problem lies somewhere in there.
bexander
Re: Kia Niro BMS
Post by bexander »
Quite some difference between storeCellVoltage:
My version:
void storeCellVoltage(uint8_t dataRegister, uint8_t readRegisterData[(2*numberOfSlaves + 5)])
	for(int i=0; i<numberOfSlaves; i++)
		uint16_t measVoltage = ((readRegisterData[(2*numberOfSlaves + 1) - i*2] << 8) + readRegisterData[(2*numberOfSlaves) - i*2]);
		measVoltage = (measVoltage >> 2) * (uint32_t)5000 / 0x3FFF;
		cellVoltage[i*numberOfCellsPerSlave + (dataRegister - 0x20)] = measVoltage;
Your:
void storeCellVoltage(uint8_t dataRegister, uint8_t readRegisterData[29])
  uint8_t cellNumberOffset = dataRegister - 0x20;
  //Serial.println(cellNumberOffset);
  for (int i = 0; i < NumModulesFound; i++)
    uint32_t measVoltage = ((readRegisterData[3 + (i * 2)] << 6) + (readRegisterData[2 + (i * 2)] >> 2));
    measVoltage = (measVoltage * 5000) / 16383;
    cellVoltageNew[i][cellNumberOffset] = measVoltage;
    // Serial.println("");
    // Serial.println(dataRegister);
    // Serial.println(measVoltage);
EDIT: This line give different array position results:
Compared to:
evdc
Re: Kia Niro BMS
Post by evdc »
bexander wrote: Sun Oct 27, 2024 3:39 pm Quite some difference between storeCellVoltage:
My version:
Your:
Compared to:
Thank you very much for your help @bexander, that was the main problem!
Best regards
Has thanked: 246 times
Been thanked: 469 times
Re: Kia Niro BMS
manny wrote: Sun Nov 05, 2023 12:04 pm
Also made a board to fit in a waterproof housing
Do have you have the gerber and bom for this?
manny
Re: Kia Niro BMS
Post by manny »
Sure.
Will put it on GitHub and post a link. Hopefully have some time to do this tonight.
  • Zombie VCU
manny
Re: Kia Niro BMS
Post by manny »
  • Zombie VCU
AmeldePamel
Re: Kia Niro BMS
Post by AmeldePamel »
bigmotherwhale wrote: Sun Nov 05, 2023 3:28 pm tidy setup, do you have contactor control on that board? I think this will need to be changed to reflect the number of modules and whether they are series / parallel
if((batteryVoltage > 300) && (compareVoltage > batteryVoltage) && (millis() - lastMillisContactor > 500))
I also found a thread on here where someone had done a similar thing to this code, it might be worth having a look, search for "MAX_Teensy_1.2"
Im interfacing with an all in one BMS with the CMUs onboard, using as much existing hardware as possible.
I realised my current sensor is only a single sensor not with high and low, and also I need an additional contactor and economizer control as well as a canbus signal from the inverter to determine voltage, so im trying to work out what I need to change in the code.
Hello. It looks like you use the original board from Kefico? What have you added to the board? Is it possible to read the CAN with these additinal boards?
bigmotherwhale
Has thanked: 17 times
Been thanked: 25 times
Re: Kia Niro BMS
Post by bigmotherwhale »
AmeldePamel wrote: Thu Dec 12, 2024 11:58 am Hello. It looks like you use the original board from Kefico? What have you added to the board? Is it possible to read the CAN with these additinal boards?
I have read the stock BMS with a elm327 and a smartphone app, but the Arduino i have crudely patched into the hardware disables the onboard micro.
It should be easy to read the battery voltages and temp through the one of the CAN ports on there, i think there are two channels. Try looking for a pinout, you just need 12v, GND and IGN, and of course the can connection, if my memory serves me well.
AmeldePamel
Re: Kia Niro BMS
bigmotherwhale wrote: Thu Dec 12, 2024 5:04 pm I have read the stock BMS with a elm327 and a smartphone app, but the Arduino i have crudely patched into the hardware disables the onboard micro.
That was my opinion as well, to easy read the CAN-port. But no such luck..
wprzybyla
Re: Kia Niro BMS
Post by wprzybyla »
maciek16c wrote: Sun Oct 08, 2023 9:09 am I think it should be possible to use stock BMS. Looks like a lot of CAN messages are the same or similar between different Hyundai / Kia models and i have Hyundai Santa-Fe PHEV battery working using Savvycan script or zombieverter (there are still some obd-2 errors, but probably not critical)
Will the Zombieverter be compatible with a battery from a Kia Ceed PHEV (96 cells, 8.9 kWh)?
77evzen77
Re: Kia Niro BMS
Post by 77evzen77 »
woleg wrote: Fri Feb 24, 2023 6:58 pm I'm just about to test a new interface which communicates with Range Rover and BMW slaves.
How has development been progressing regarding software, do many unknowns remain?
Hi, I would like to ask where it would be possible to get the module that is in the 6QupRET.jpeg with MAX17841??? many Thank Evzen
woleg
Has thanked: 14 times
Been thanked: 13 times
Re: Kia Niro BMS
Post by woleg »
77evzen77 wrote: Tue Mar 04, 2025 4:13 pm Hi, I would like to ask where it would be possible to get the module that is in the 6QupRET.jpeg with MAX17841??? many Thank Evzen
I have one left. It’s not too difficult to reuse the hardware from the vehicle if you have the main control module.
77evzen77
Re: Kia Niro BMS
Post by 77evzen77 »
Hello, if you have another one, I would be interested please, what would be the price of the ???Thank for your answer.
