ZombieVerter VCU Connector Depinning Tool
- Gregski
- Has thanked: 635 times
- Been thanked: 1611 times
not sure where this belongs so dropping it here, hope it helps somebody out
REMOVAL TOOL FOR FEMALE TERMINALS
Manufacturer: Aptiv (formerly Delphi)
TTI Part Number: 210S048
Mfr Part Number: 210S048
Price: $65
Price: $65
- Gregski
Re: ZombieVerter VCU Connector Depinning Tool
used for depinning this type of harness from AliExpress
the orange thing appears to be just a shield to either prevent the tool from getting damaged or you from getting cut, maybe
Woodfie
- Has thanked: 221 times
- Been thanked: 96 times
Thanks for info, have been removing some with less sophisticated jewelers screwdriver method.
On a related track, pinout for the Zombie board, Mth, Htm, Req, and Clk etc. For use with Prius Nvw30 inverter,
Can you point me as where to locate this please.?
Thanks.
Thanks.
- Gregski
Woodfie wrote: ↑Fri May 10, 2024 4:11 am Thanks for info, have been removing some with less sophisticated jewelers screwdriver method.
Thanks.
it will be my next video, in the meantime please see if this thread can help
Prius Gen 3 Inverter Connector Pin Out Dumbed Down
Woodfie
Thanks for the link, Ots the Zombie pins am presently searching for..
Your videos are very helpful thanks, look forward to it..
Had figured there must be a diagram about, my limited searching ability has found this on an old post for gs450h,
Do you know if this suits for the Prius you have in the Rabbit? I guess all the oil pump etc is ignored.
- Gregski
that looks similar to what's on the Wiki https://openinverter.org/wiki/ZombieVerter_VCU#Installation
all you need is the four pairs of wires from the Inverter to the Zombie, there are four sets of three wires shown in the diagram below because the third wire from each wire pair loops back to the inverter plug
royhen99
- Has thanked: 22 times
- Been thanked: 134 times
Best to use the pinout from the wiki as I corrected the can and can2 positions. Older posts on the forum may have this incorrect.
ScythianNite
- Has thanked: 97 times
- Been thanked: 11 times
thanks gregski! This feels like something that should be documented in the wiki, but where would a good spot be?
update: I added it to the hardware section immediately after the prewired connector w/ leads line item
unfortunately formatting is terrible because I don't really know what I'm doing
- Gregski
ScythianNite wrote: ↑Sat May 11, 2024 12:17 am thanks gregski! This feels like something that should be documented in the wiki, but where would a good spot be?
a Specialty Tools section wouldn't hurt
Woodfie
Thanks all for your inputs.ScythianNite wrote: ↑Sat May 11, 2024 12:17 am thanks gregski! This feels like something that should be documented in the wiki, but where would a good spot be?
Had been looking for Prius label, when its presently looked more like Leaf , I Didn't notice the sync serial is universally there..
I guess this is all stated somewhere that I haven't come across... Just wondering best way to guide fumbling folks like myself in the right direction..
Greg's videos are very helpful ,
Perhaps at some stage, links to this connection information, if was shipped with the board would have been a good starting point for me..
Not sure how to get feedback to help this, without seemingly like being a nuisance .
Just trying to think of paths to help newer stumbling folks..
- Gregski
Woodfie wrote: ↑Sat May 11, 2024 1:21 am Thanks all for your inputs.
Step 1. ask questions, like you did, you are already ahead of the game (if you think you are the only one confused or timid about asking, you are dead wrong, you are doing others a favor by asking)
Step 2. network, click on the persons name aka handle then click on add friend, 99% of them will accept, guys live to talk EV, then private message them a question if you are embarrassed to ask in public
Woodfie
Thanks for helping....have the connections sorted ready for when have a Zombie board prepared.
Next to assemble supplied chips, and wifi module.
The Damian Maguire video I found has guidance to installing a wifi board , not the Esp one, which could be flipped over and seemingly incorrectly installed.
Is there another video description , or instructions that I haven't come across that would help me.with this next step ?
- Gregski
Woodfie wrote: ↑Mon May 13, 2024 3:28 am Thanks for helping....have the connections sorted ready for when have a Zombie board prepared.
That looks great, awesome job Woodfie, so see if this thread will help
EVBMW Zombieverter Videos Table of Contents
Woodfie
Perfect.... Thanks Greg,
Was able to go straight to the Feb 2023 video titled with Blue wifi Module. And Tap into Exactly what I need to help .
Many Thanks for the Great Complimation of Damians contributions.. I was struggling to find the right spot..to look.
- Gregski
Woodfie wrote: ↑Mon May 13, 2024 7:49 pm Perfect.... Thanks Greg,
Many Thanks for the Great Complimation of Damians contributions.. I was struggling to find the right spot..to look.![]()
it does feel like drinking out of a fire hose sometimes
- Gregski
Thanks.
seems like you guys are always a week or so ahead of me with your questions and the videos I am working on, lol, hope you find this video useful
ZombieVerter VCU Prius Inverter Connection
it's going to look like this for both the 3rd Gen Toyota Prius and Lexus GS450h inverters
Woodfie
attachment=0]20240519_100543.jpg[/attachment]
Great presentation thanks... helpful to recall the "Unwrapping" of the communication 4 pairs etc.
Had made up a Test Loom some time ago in an attempt to connect the450h vcu to a Prius inverter..
This is being re purposed for Zombie vcu to Prius.
PICTURE is of cut test loom, laid over the mg1 and mg2 phase lines.
Interesting that the staggered joints to the shielded leads that head to the Toyota vcu, are directly over the motor phase wires.. Hence the extra shield that you found over the plastic protection tube..
Did you if find that extra shield, shown between the arrows ,
Question please ...
I think this was a copper wrap , So was connected to ground, or was it just floated..?
I haven't got another original loom to pull apart at present.
Also had yesterday cut the loom in a place, that is requiring remaking of custom screening ..
Oh well can't get it wrong all of the time, BUT do keep trying.
Question please ...
