Nissan Leaf Gen3 Drop-in board
- uhi22
- Has thanked: 244 times
- Been thanked: 684 times
Re: Nissan Leaf Gen3 Drop-in board
Thanks for these deep insights. The split termination indeed reduces the common-mode disturbances, which could be helpful in noisy environments. With the cost, that it needs well-matched resistors to avoid translating the common-mode-noise to differential noise, which would be worse. So yes, it is the safe way for designing the termination. And a safe design is much better than sporadic issues in the field. So I can only say: Thank you for your professional work.
- Been thanked: 1913 times
Just tried opening the project and there seem to be some missing files:
Fehler traten beim Laden der Footprints auf:
Footprintbibliothek "/home/johu/Projekte/e-umbau/kicad/Nissan-Leaf-Gen-3-Adapter-Board/V0.0.4/Footprints" nicht gefunden.
Footprintbibliothek "${KICAD_LIB}/JLCPCB/JLCPCB.pretty" nicht gefunden.
Footprintbibliothek "C:/Users/jeremxxxx/Desktop/Personal Projects/Open Inverter/Nissan Gen3 Inverter/Gen 3 Leaf Adapter" nicht gefunden.
Footprintbibliothek "/home/johu/Projekte/e-umbau/kicad/Nissan-Leaf-Gen-3-Adapter-Board/V0.0.4/Symbols" nicht gefunden.
Footprintbibliothek "/home/johu/Projekte/e-umbau/kicad/Nissan-Leaf-Gen-3-Adapter-Board/V0.0.4/TPS61175.pretty" nicht gefunden.
- Has thanked: 360 times
- Been thanked: 249 times
Kicad libraries is definitely somewhere that I struggle, sorry for the issue.
I have uploaded the folders & files to github and reorganized the folder structure to mimic what I think the missing files snip is showing. I did add these files in the project, I think Kicad will find them... You may have to add the library locations manually for the errors after you download the new version if Kicad doesn't find them. Please sync or toss that copy and pull from github again.
TPS61175 is an old artifact from the i3 adapter I referenced very early on, I did not find the symbol or footprint anywhere that it is referenced in this current leaf adapter.
Kicad recovery might find them too since they should all be in the project folder now.
Let me know how it goes.
Finally got around to installing into the inverter (V0.0.3 board) and see here there might be some TMPHS issues. Mine is showing 100 degrees constantly in room temperature without load. Is this something you also were seeing and found a solution to? Maybe the scaling is different, see this for UDC at least. I have found udcofs=40 and udcgain=9.5 to give resonable values. (250 and 6.09 for the gen2)johu wrote: ↑Mon Feb 12, 2024 7:43 pm Finally got to this again.
One of the 5V pins had lifted off the pad thus disabling UDC and TMPHS measurement. All works as before now.
Good one
With the STM32 in reset it sits at 0.544V instead of the calculated 0.4V. So then I cut the brake jumper and now in reset it sits at 0.75V. With the main board removed and 5.3V applied I read 0.45V. Strange.
I looked for differences between the Gen2 board where the STM32 always boots ok and the Gen3. I think it's the boot delay cap C13. I removed it, now the STM boots every time. It seems somehow the ESP32 sends the magic 0xAA when starting and with the boot delay this coincides with the boot loader waiting for 0xAA. So the fact that it works on all other boards is more out of luck...
Positive for the SMT part. Don't have the THT one.
The brake output doesn't change. When I activate it I get 2.6V on TP_A1 and 0.7V behind the Zener. So I replaced the Zener with a low value resistor, then the brake output works. Without the Zener the brake light will briefly (200ms) turn on above certain variant codes when booting. Don't think that's too much of an issue.
Seems to be some sort of redundancy. Current readings are the same with or without the jumpers.
Solid GND, it's the GND of the current sensor
Right now I get 3V at room temperature. That's a bit close to the end of the dynamic range indeed. Will test other values. Maybe back to standard OI 1k2.
Will check. What chatter are we talking about though?
Yeah not quite sure if there's a beneficial use for these. On the Gen2 board I just ignore the duplicates.
jrbe wrote: ↑Tue Feb 06, 2024 12:56 am
-R13 is a pull down resistor for the T_SINK input. This is at 3K3 in V0.0.1 but unsure if this is ideal. There are 2 plated thru holes on each side of R13 to use to make testing the ideal value easier.
-The capacitors on each contactor mosfet gate should be checked that they do not delay turn on or off too much and that they help eliminate chatter. If they are too large they could run the mosfets in the linear region and could cause damage.
-a bunch more...
R13 was a 3k3 and was swapped to 1k2. Johu tested that the 3k3 was too high but the 1k2 might end up too low.
I left the plated through holes next to R13 to allow swapping in different through hole resistors for testing to try to shift the temp sensor voltage swing into a more usable range. I didn't have any specs of the temp circuitry.
There are a bunch of other things in V0 0.3 that also need to be checked. It's on the first page of this thread, it's pretty long. If you tap the up arrow next to my quote it will bring you to that post.
The link to the unresolved items are things in between V0.0.3 & V0.0.4.
Quite simply the curve of the temperature sensor was never measured and programmed into the firmware.
Thanks, both.
JRBE, you were on the right track, but still not low enough. 0K5 brought it down to room temperature with the Gen2 profile, but unsure if it fits the old profile from there. Now to some testing with load...
Hah, goes opposite direction vs temp so definitely needs new profile in fw and maybe the 1K2 resistor is OK anyway.
ted.walsh
- Has thanked: 33 times
- Been thanked: 23 times
First can I say how appreciative of the amazing work everyone is doing in this thread. I can hardly wait to get my hands on a production example!
Not wanting to clutter the thread, Im running a G3-160KW with zombie + 28kwh pack. the long and the short is that the stock inverter appears to be shutting itself down due to an overtemp condition after 3 to 4 mins of hard running, If i come off the power and pootle along for a min or so I can then go full throttle again for a while - could this be indicative of a FW temp mapping / handling issue like you describe?
Had a shot at getting things moving over the weekend, but only rattling/sounds so far and going into DESAT error if too much torque(POT) applied. Resolver input is giving nice plot. Guess there are settings/jumpers that needs to be figured out though... Happy to test things out, only using 48V so probably not able to break anything on the high voltage side? Using EM57 motor settings that are working with a Toyota inverter, so guess investigation is on the inverter side.
Maybe add resolver to pinswap?
Has anyone compiled parameters that will work with the stock motor? I tried to compile from this thread viewtopic.php?t=980&hilit=udc&start=75. The settings I have tried below:
Especially unsure about the "il1gain": 1.81 and "il2gain": 1.81, stated as negative, but is this true.
"iqkp": 60,
"idkp": 32,
"curki": 20000,
"vlimflt": 10,
"vlimmargin": 5000,
"fwcurmax": 0,
"syncofs": 48700,
"lqminusld": 0.25,
"fluxlinkage": 73,
"syncadv": 10,
"polepairs": 4,
"respolepairs": 4,
"sincosofs": 2048,
"encmode": 4,
"fmax": 130,
"numimp": 60,
"dirchrpm": 100,
"dirmode": 4,
"snsm": 14,
"pwmfrq": 2,
"pwmpol": 1,
"deadtime": 180,
"ocurlim": 100,
"il1gain": 1.81,
"il2gain": 1.81,
"udcgain": 10,
"udcofs": 50,
"udclim": 240,
"snshs": 6,
"pinswap": 6,
"modmax": 37836,
"potmin": 0,
"potmax": 4095,
"pot2min": 4095,
"pot2max": 4095,
"potmode": 2,
"throtramp": 4,
"throtramprpm": 20000,
"throtcur": 5.5,
"brakeregen": -10,
"regenramp": 0.28,
"regentravel": 13,
"offthrotregen": -10,
"cruiseregen": -10,
"regenrampstr": 10,
"brklightout": -50,
"bmslimhigh": 50,
"bmslimlow": -1,
"udcmin": 20,
"udcmax": 240,
"idcmax": 200,
"idcmin": -100,
"idckp": 1,
"idcflt": 9,
"tmphsmax": 150,
"tmpmmax": 300,
"throtmax": 100,
"throtmin": -100,
"accelmax": 1000,
"accelflt": 3,
"chargemode": 0,
"chargecur": 0,
"chargekp": 80,
"chargeki": 10,
"chargeflt": 8,
"chargepwmin": 0,
"chargepwmax": 90,
"idlespeed": -100,
"idlethrotlim": 50,
"idlemode": 3,
"holdkp": -0.25,
"speedkp": 0.25,
"speedflt": 5,
"cruisemode": 0,
"cruisethrotlim": 50,
"udcsw": 20,
"udcswbuck": 540,
"tripmode": 0,
"bootprec": 0,
"pwmfunc": 0,
"pwmgain": 0,
"pwmofs": 2048,
"canspeed": 1,
"canperiod": 0,
"nodeid": 1,
"controlid": 63,
"controlcheck": 0,
"manualstart": 0,
"manualiq": 0,
"manualid": 0
With above settings rotating shaft clockwise (facing the shaft) angle plot goes from low to high. Should it go from high to low, i.e. removing the SINCOS pinswap?
Tried both removing the SINCOS pinswap as well as negating the current sensor settings
"ocurlim": -100, "il1gain": -1.81, "il2gain": -1.81
No movement with syncofs=0 and manualid up to 12A on any settings, so maybe I have bricked something. Reports overcurrent. Have not tested with other pinswap settings. Also goes into overcurrent error when I manually turn the shaft a couple of turns. Have another inverter but do not risk it before finding out...
Plot when in in manual mode with everything set to 0, that amplitude seems high to me, +-15 with no manualid. And il1 and il2 should not be in phase, should they?
Maybe I get a chance to test with Zoe motor
That would be awsome, will be good to get params that is constant for the physical stuff like pin swapping and the current sensor gains. In my book none of the phases should align, so the plot above does not make sense to me.
Update: added digikey links for THT connectors to opening post.
We have tested with glinks setup quite a bit but never got stable current control. I experimented with my own inverter and arrived at the conclusion that negative gains are needed. When connecting positive voltage on the IGBT side of the current sensor and negative on the outside bus bar the reading is negative. Also verified with a scope. The sensitivity is -2.5 mV/1A. That would result in a ilXgain of -3.1
With some more testing I figured the phase order.
The one without current sensor is phase 3, then 2, then 1. Also phase 1 is sensed by il1 and phase 2 by il2. No inverter pin swapping needed.
The mystery is, we did try with these settings but the current control loop ran away. So commanding 5A manualid resulted in 100A phase current and triggered the current limit.
Maybe the controller gains are off or 100A is too low and triggered by overshoot.
I'm happy to see some work happening with this.
You guys have a heater in line to the battery for testing? I thought >150A was required to get a leaf motor turning.Zieg wrote: ↑Mon Apr 15, 2024 3:23 am I also tried to calibrate my Syncofs but even after going up to 150 amps I was not getting motion from the motor. I think it may just have been pretty close to the ideal number though. I used Johu's settings as a starting point, and I can't imagine the difference from one EM57 to another is terribly massive.
No heater in my case, just a lightbulb for first powerup. Since writing that I discovered that my syncofs was actually a few thousand off, and that was enough to cause driveability issues but very difficult to detect with the drivetrain connected and wheels off the ground. Are you wondering what it takes to get the motor going with correct syncofs? I've got the car on blocks right now for some suspension work so I could run a test this weekend if you can tell me what you want to see.
It was more a reference for these guys trying to get the gen3 lead drop in board turning a leaf motor, sounds like they might be 50 amps low. They likely won't have a good syncofs until they can get it moving.
It sounded like you got the syncofs set pretty well. It would likely be a good thing to know what phase current is required to get the motor turning with that set well, if it's much different.I've got the car on blocks right now for some suspension work so I could run a test this weekend if you can tell me what you want to see.
Sorry, I didn't mean to pull you into this, just meant to share the reference of what you used to get yours spinning but with a different inverter.
Ah, gotcha. I don't know exactly what was going on when I first tried it, best guess is the drivetrain friction/inertia was messing things up and I should have gone higher. I also discovered that being off by a few thousand was more than enough to cause problems like unwanted acceleration above a certain speed. That certain speed also got lower as I got further away from the correct setting. As low as 60kph with my 195/50R16 tires.
Eventually I ended up just incrementing the value and driving the car forward and back in a parking lot until I had it dialed in. I think that's a good way to verify your setting but I wouldn't recommend getting yourself stranded and having to resort to that method as I did. Lol.
I added those connector options to the Nissan Leaf Gen 3 wiki. Looks those are the only ones available through typical retailers, good find!
Do they solder and attach to the board well?
