Zombieverter Leaf throttle code
ted.walsh
Has thanked: 9 times
Been thanked: 8 times
Post by ted.walsh »
code help required for wringing the most out of the 160kw inverter...
// Requested torque (signed 12-bit value + always 0x0 in low nibble)
if(final_torque_request >= -2048 && final_torque_request <= 2047)
this is a snippet from the Zombieverter repository that is compiled into the current live version for the VCU, it appears to limit the maximum torque request to a value below 2047 and be a hangover from the V1 hardware days as the same value is used there. notwithstanding V2.x doesn't have specific support for the 110 and 160 inverters yet, has anyone tried monkeying with the value? Ive looked at the Dala code for his middleware solution and it doesn't seem to do anything other that multiply the final value by 1.47 (up to 1.6!) on the 160 and 1.32 on the 110.
Any thoughts or better still real world experience by anybody?
Has thanked: 106 times
Been thanked: 231 times
Re: Zombieverter Leaf throttle code
Do you have a setup with a Gen 3 drivetrain that runs to test on? I will dig a bit in the DBCs to see what limits are listed there.
You are looking at the wrong point buddy. It is a 12bit value thus 4095 dec max and then half that because its signed gives you the value limits listed in the code.
Here is a a log from a 62kwh car
The way the torque gets requested is a bit strange.
So it scales from 0-100 as torque percentage then multiplies by 2047. Given the motor torque is scaled at 0.25 bit/Nm and its a 12bit value.
This would mean 2047*0.25 = 511.75Nm which sounds like quite alot.
void LeafINV::SetTorque(float torquePercent)
   final_torque_request = (torquePercent * 2047) / 100.0f;
   Param::SetInt(Param::torque,final_torque_request);//post processed final torque value sent to inv to web interface
Probally want to update the 0x1DC limits to the ones form a gen 3 log like below.
These values are currently hardcoded in the Zombie code
If anyone one could please provide a CAN log of a Zombie controlling a Nissan Leaf inverter, I would like to see a log with the throttle flat requesting 100%. Please provide the Zombie settings with the log.
Aragorn
Has thanked: 5 times
Been thanked: 53 times
Post by Aragorn »
I'm sure dala ran some tests where if you request more torque than the inverter allows, the inverter will just follow the programmed curve. Perhaps Zombie really is requesting 500nm? That must give weird throttle control though, as it will reach max torque at 50-60% pedal?
Aragorn wrote: Mon Jan 08, 2024 12:01 pm I'm sure dala ran some tests where if you request more torque than the inverter allows, the inverter will just follow the programmed curve. Perhaps Zombie really is requesting 500nm? That must give weird throttle control though, as it will reach max torque at 50-60% pedal?
Exactly why I am asking for logs, so I can review the request and the response from the inverter.
ted.walsh
Post by ted.walsh »
thanks for the help, Ill get a can logger and run a scan on the bus...
ted.walsh
Post by ted.walsh »
tom91 wrote: Sat Jan 06, 2024 8:52 pm Probally want to update the 0x1DC limits to the ones form a gen 3 log like below.
Im Hoping to get some logs this weekend but in the mean time im going to change 0x1dc as suggested- is it just byte [1] I need to change or [1] & [2]? I cannot quite figure out the cryptic message in the .cpp comments
ted.walsh wrote: Wed May 08, 2024 9:23 am Im Hoping to get some logs this weekend but in the mean time im going to change 0x1dc as suggested- is it just byte [1] I need to change or [1] & [2]? I cannot quite figure out the cryptic message in the .cpp comments
"cryptic" because its just copy paste from a log.
Here is the format of the values.
So you the 10bit discharge limit is: 0x1B8 440d. The scaling is 0.25kW per bit, luckily its hex and if you shift it back 2 positions you are dividing by 4.
The discharge limits thus is 0x6E which is 110d kW
So what value do we want to try, lets say 150kW 0x69. Then shift this left 2 you get 0x258 or 600d.
bytes[0]=0x6E;
bytes[1]=0x0A;
Becomes
bytes[0]=0x96;
bytes[1]=0x0A;
