The SuperYacht BMW E65 7 Series
mfox
Re: The SuperYacht BMW E65 7 Series
Post by mfox »
that's great. :)
How much power is expected ?
xp677
Been thanked: 15 times
Post by xp677 »
Jack Bauer wrote: Wed Nov 13, 2019 8:53 am I think they changes to a newer type of inverter in 2009. LDH/RHD should make no difference. I do have a 2013 inverter that I plan on testing.
Old post, but if it helps, I'm using a 2007 inverter on a 2010 transmission and all is fine.
The model type ended in 2011.
Kevin Sharpe
Been thanked: 8 times
Post by Kevin Sharpe »
mfox wrote: Sat Dec 21, 2019 1:10 am How much power is expected ?
Estimates are 220kW/300HP... we won't know for sure until we stick it on the dyno in the spring.
Over the next three months we will measure acceleration, top speed, test the dual speed gearbox, and validate cooling strategies. We will also get the car inspected by an automotive engineer, change taxation to electric drive, and get it through a national vehicle test.
Once all that's complete we'll put some miles on it as a daily driver and undertake some towing tests at the 2100kg car limit. Then it's long range battery, CCS rapid charging, etc., etc. :D
mfox
Post by mfox »
excelent,
this is like small drive unit, but more sutable for RWD and cca 3x cheaper
yesterday I bought gearbox and inverter, can't wait when it comes. :D
Kevin Sharpe
The Super Yacht (aka BEXUS) was inspected and passed by an automotive engineer today... next steps include changing the taxation class to electric drive, NCT, and testing on track and road 8-)
Kevin Sharpe
xp677
Post by xp677 »
Nice. I'm using the same Tesla charger and TRW pump on my project :)
What are you using for a DC-DC converter?
Alexstarex
Post by Alexstarex »
xp677 wrote: Fri Jan 31, 2020 6:55 pm Nice. I'm using the same Tesla charger and TRW pump on my project :)
I think from Lexus 450
xp677
Post by xp677 »
I can't imagine that the GS DC-converter is suitable, as it's rated to 288v input.
RE3Rotor
Post by RE3Rotor »
Is there a break down of the different components for the SuperYacht? I have a Subaru Forester I am looking to convert with the same GS 450h gearbox and is looking for information on this build.
Igor
Has thanked: 19 times
Post by Igor »
Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
RE3Rotor
Post by RE3Rotor »
Igor wrote: Fri Feb 07, 2020 7:24 am Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
From what I have gathered:
GS450h gearbox
GS450h inverter w/ his opensource control board
Tesla Gen 3 (?) charger w/ his opensource control board
I also would like to know if he has BMS with the batteries, and what else is inside that high voltage junction box.
Kevin Sharpe
RE3Rotor wrote: Fri Feb 07, 2020 7:01 pm I also would like to know if he has BMS with the batteries
No physical BMS is used with the test pack (it's monitored manually). When the long range pack is fitted then I suspect it will use the BMS fitted to the modules (if OEM) or Johannes BMS.
RE3Rotor wrote: Fri Feb 07, 2020 7:01 pm what else is inside that high voltage junction box.
Contactors and Precharge relay/resistor.
xp677
Post by xp677 »
Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Alexstarex
xp677 wrote: Sun Feb 09, 2020 2:44 pm Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Yes. all right
xp677
Post by xp677 »
Excellent, thank you.
Kevin Sharpe
Look out for update video from Damien :)
Has thanked: 10 times
Been thanked: 335 times
Bexus Lives!!!!
So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
Has thanked: 369 times
Been thanked: 1543 times
Thats super amazing. Who said electric motors can't have good sound ;)
I wonder how they react at road worthiness test.. sir, we can see a gear box but where is this cars motor?
Zapatero
Has thanked: 25 times
Been thanked: 42 times
Post by Zapatero »
Love the sound, very cool. :D
JaniK
Has thanked: 58 times
Been thanked: 14 times
Post by JaniK »
Great sounds. That bexus is very good proof of concept!
RE3Rotor
Post by RE3Rotor »
Jack Bauer wrote: Wed Feb 12, 2020 4:47 pm So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
What is the range for a 450V pack?
sfk
Post by sfk »
RE3Rotor wrote: Wed Feb 12, 2020 6:34 pm
Voltage doesn't dictate range. Kilowatt hours is a better general indicator.
But weight of car, driving style, terrain and even climate factor into the range calculation.
RE3Rotor
Post by RE3Rotor »
I guess a better question to ask is how much kWh does Damiens pack have? And that is driving the motors at all of 450V? Is there any boosting using the boost converter?
