How much power is expected ?
The SuperYacht BMW E65 7 Series
xp677
- Been thanked: 15 times
Re: The SuperYacht BMW E65 7 Series
Old post, but if it helps, I'm using a 2007 inverter on a 2010 transmission and all is fine.Jack Bauer wrote: ↑Wed Nov 13, 2019 8:53 am I think they changes to a newer type of inverter in 2009. LDH/RHD should make no difference. I do have a 2013 inverter that I plan on testing.
The model type ended in 2011.
- Kevin Sharpe
- Been thanked: 10 times
Estimates are 220kW/300HP... we won't know for sure until we stick it on the dyno in the spring.
Over the next three months we will measure acceleration, top speed, test the dual speed gearbox, and validate cooling strategies. We will also get the car inspected by an automotive engineer, change taxation to electric drive, and get it through a national vehicle test.
Once all that's complete we'll put some miles on it as a daily driver and undertake some towing tests at the 2100kg car limit. Then it's long range battery, CCS rapid charging, etc., etc.
excelent,
this is like small drive unit, but more sutable for RWD and cca 3x cheaper
yesterday I bought gearbox and inverter, can't wait when it comes.
- Kevin Sharpe
The Super Yacht (aka BEXUS) was inspected and passed by an automotive engineer today... next steps include changing the taxation class to electric drive, NCT, and testing on track and road
- Kevin Sharpe
xp677
Nice. I'm using the same Tesla charger and TRW pump on my project
What are you using for a DC-DC converter?
Alexstarex
xp677
I can't imagine that the GS DC-converter is suitable, as it's rated to 288v input.
Is there a break down of the different components for the SuperYacht? I have a Subaru Forester I am looking to convert with the same GS 450h gearbox and is looking for information on this build.
Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
From what I have gathered:
GS450h gearbox
GS450h inverter w/ his opensource control board
Tesla Gen 3 (?) charger w/ his opensource control board
I also would like to know if he has BMS with the batteries, and what else is inside that high voltage junction box.
- Kevin Sharpe
No physical BMS is used with the test pack (it's monitored manually). When the long range pack is fitted then I suspect it will use the BMS fitted to the modules (if OEM) or Johannes BMS.
Contactors and Precharge relay/resistor.
xp677
Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Alexstarex
- Kevin Sharpe
Look out for update video from Damien
- Been thanked: 1123 times
So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
- Been thanked: 1914 times
Thats super amazing. Who said electric motors can't have good sound
I wonder how they react at road worthiness test.. sir, we can see a gear box but where is this cars motor?
- JaniK
- Has thanked: 101 times
Great sounds. That bexus is very good proof of concept!
What is the range for a 450V pack?Jack Bauer wrote: ↑Wed Feb 12, 2020 4:47 pm So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
Voltage doesn't dictate range. Kilowatt hours is a better general indicator.RE3Rotor wrote: ↑Wed Feb 12, 2020 6:34 pmWhat is the range for a 450V pack?Jack Bauer wrote: ↑Wed Feb 12, 2020 4:47 pm So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
But weight of car, driving style, terrain and even climate factor into the range calculation.
I guess a better question to ask is how much kWh does Damiens pack have? And that is driving the motors at all of 450V? Is there any boosting using the boost converter?
