How does AC (smart) charging actually work? PWM explained!
Has thanked: 631 times
Been thanked: 1607 times
very detailed explanation if you want to test your inner Geek
Re: How does AC (smart) charging actually work? PWM explained!
Video Takeaways With Direct Links Back To The Video
Two Different Types of Charging Plugs
The EVSE Can Show One Of Six Different States / or Statuseses
EVSE Status: A, B, C, D, E, F
Status C/D
C = Charging
D = in the old days of lead acid batteries meant Charging with Ventilation
Has thanked: 330 times
Been thanked: 847 times
https://en.wikipedia.org/wiki/SAE_J1772 This has all the bits you are covering listed per topic.
xvyDFatih
Post by xvyDFatih »
How can we detect that an ac or dc charger is plugged?
Gregski wrote: Wed Oct 04, 2023 2:32 pm very detailed explanation if you want to test your inner Geek
DC chargers go into 5% duty cycle, thus requesting digital communications instead of PWM.
uhi22
Has thanked: 245 times
Been thanked: 684 times
Post by uhi22 »
Yes, and AC chargers have two possibilities: Either use a higher PWM ratio, which defines the allowed current, or apply 5% and announce in the high level communication (IP, TCP, V2GTP, EXI) during the negotiation of the charge parameters that they support AC.
