How does AC (smart) charging actually work? PWM explained!
- Gregski
- Has thanked: 631 times
- Been thanked: 1608 times
very detailed explanation if you want to test your inner Geek
- Gregski
Re: How does AC (smart) charging actually work? PWM explained!
- Gregski
- Gregski
- Gregski
- Gregski
- Has thanked: 330 times
- Been thanked: 847 times
https://en.wikipedia.org/wiki/SAE_J1772 This has all the bits you are covering listed per topic.
How can we detect that an ac or dc charger is plugged?
DC chargers go into 5% duty cycle, thus requesting digital communications instead of PWM.
- uhi22
- Has thanked: 245 times
- Been thanked: 684 times
Yes, and AC chargers have two possibilities: Either use a higher PWM ratio, which defines the allowed current, or apply 5% and announce in the high level communication (IP, TCP, V2GTP, EXI) during the negotiation of the charge parameters that they support AC.
