Subaru e-mpreza (Impreza) 96 - AWD with 2 Outlander rear motors
- Zapatero
- Has thanked: 25 times
- Been thanked: 43 times
Re: Subaru e-mpreza (Impreza) 96 - AWD with 2 Outlander rear motors
I'm almost done wiring the car, almost everything works by now.
As we figured out that the Zombieverter could only drive the rpm OR the speedometer i decided for the speedometer and put an digital gauge in place of the rpm gauge.
It's a canchecked MFD28 display that comes with software and can literally show anything on the Canbus.
- marcexec
- Has thanked: 888 times
- Been thanked: 91 times
Looks awesome!
What's the Zombieverter's limitation in your case there?
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
- EV_Builder
- Been thanked: 37 times
Don't forget to make it dimmable with an input or so.
Displays can be very bright at night.
- Has thanked: 455 times
- Been thanked: 1771 times
It has 3 PWM outputs but they all run at the same frequency. Speedometer and rev counter need a (different!) variable frequency so you must pick which one you want to run.
- EV_Builder
Which frequencies, how high do we talk about?
The speedo is 166 Hz at 250 km/h
We never tested the rev counter
- Zapatero
Successfully tested on the Canbus so far:
Power steering and steering angle sensor
Orion BMS
BMW Lim
IBooster Brake
On the Zombieverter VCU:
Electric power pedal
Brake pedal
Forward/reverse switch and 4WD switch
Cruise Control
Heater control
Also the radio controls through the steering wheel are working with the new radio.
Pretty nice for a 1996 Impreza
Laying on the dashboard you can see the openpilot hardware! O already integrated the openpilot box into the car harness.
Looks like a car again:
Orion BMS
BMW Lim
IBooster Brake
Brake pedal
Cruise Control
Heater control
- Boxster EV
- Has thanked: 57 times
- Been thanked: 49 times
Impressive how quickly you are bringing this build together. Inspiring stuff.
- benr
- Has thanked: 4 times
Did you mount one of the Outlander motors in the reverse orientation of the others? I take it there's no issue running it the other way round?
I'm thinking I might have to do this in my long-planned build.
- Zapatero
Update: Johannes and me had another session and everything works so far. Now i just have to put the batteries in. Unfortunately part 2 of the house renovation is taking up all my time and it'll be another 2-3 weeks until i can work on the subaru again!
- Zapatero
I don't know yet for sure as i didn't drive it, BUT i still have plan B: Swap 2 cables of the connection between inverter and motor and swap the resolver cables according to it, then it'll spin backwards thinking it's spinning forward. Motor won't even know whats happening
- Zapatero
Finally, after a battery disaster, i am moving forward with this conversion. I sold the Kona-Battery as the TÜV-Guidelines for building EVs in Germany have been changed while i built this Impreza, saying that an energy storage unit can't be any closer than 400mm to the front end of the bumper and 300mm to the rear end of the bumper. I bought the Leaf-Battery with 40 KwH from Marty from this forum. That Pack is so much easier to install!!!
Yesterday we welded the battery boxes and put half the Pack und the back. The planned watercooling won't work now, but i'm planning on aircooling them.
Tomas
- Has thanked: 34 times
- Been thanked: 4 times
Plenty of space at the front! Very impressive and factory-looking build
- elShankos
- Been thanked: 11 times
Thanks a lot for sharing all this info - super helpful as I'm about to pull the engine out of my Legacy GT (3rd Gen) to build battery boxes up front. Did you do any 3D modelling to plan the space at all? Just curious.
- Zapatero
I'm sad and sorry to tell, but due to personal circumstances i decided to stop this EV-Conversion.
All the Parts will be listed for sale.
Alibro
- Has thanked: 417 times
- Been thanked: 277 times
Sorry to hear that as I enjoyed following this build but sometimes life happens and we have to move on.
Good luck and hopefully we will see you back here again sometime.
Pete9008
- Has thanked: 102 times
- Been thanked: 350 times
Sorry to hear that, hope you get everything sorted out.
thomaa
- Has thanked: 17 times
- Been thanked: 7 times
That's a huge shame. Best of luck with life and hope to see you back with some great projects.
Your 86 conversion was brilliant. newbie here but that has put pipe dreams in my head to try the same some day.
Ruudi S
- Has thanked: 55 times
- Been thanked: 32 times
How did you make the CAN bus working? I'd like to make 2008 diesel Legacy CAN happy, without the engine and make the electric power steering rack turn on.Zapatero wrote: ↑Wed Dec 28, 2022 10:09 pm Successfully tested on the Canbus so far:
Orion BMS
BMW Lim
IBooster Brake
Brake pedal
Cruise Control
Heater control
Pretty nice for a 1996 Impreza![]()
Did you hack that or your car didn't have those problems?
