Subaru e-mpreza (Impreza) 96 - AWD with 2 Outlander rear motors
Zapatero
Has thanked: 25 times
Been thanked: 42 times
Re: Subaru e-mpreza (Impreza) 96 - AWD with 2 Outlander rear motors
Post by Zapatero »
I'm almost done wiring the car, almost everything works by now.
As we figured out that the Zombieverter could only drive the rpm OR the speedometer i decided for the speedometer and put an digital gauge in place of the rpm gauge.
It's a canchecked MFD28 display that comes with software and can literally show anything on the Canbus.
marcexec
Has thanked: 760 times
Been thanked: 72 times
Post by marcexec »
Looks awesome!
What's the Zombieverter's limitation in your case there?
Getting started guide for Celeron55's iPDM56
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
EV_Builder
Post by EV_Builder »
Don't forget to make it dimmable with an input or so.
Displays can be very bright at night.
Has thanked: 368 times
Been thanked: 1536 times
marcexec wrote: Mon Dec 26, 2022 1:36 pm What's the Zombieverter's limitation in your case there?
It has 3 PWM outputs but they all run at the same frequency. Speedometer and rev counter need a (different!) variable frequency so you must pick which one you want to run.
EV_Builder
johu wrote: Tue Dec 27, 2022 11:51 am It has 3 PWM outputs but they all run at the same frequency. Speedometer and rev counter need a (different!) variable frequency so you must pick which one you want to run.
Which frequencies, how high do we talk about?
The speedo is 166 Hz at 250 km/h
We never tested the rev counter
Zapatero
Post by Zapatero »
Successfully tested on the Canbus so far:
Power steering and steering angle sensor
Orion BMS
BMW Lim
IBooster Brake
On the Zombieverter VCU:
Electric power pedal
Brake pedal
Forward/reverse switch and 4WD switch
Cruise Control
Heater control
Also the radio controls through the steering wheel are working with the new radio.
Pretty nice for a 1996 Impreza :)
Laying on the dashboard you can see the openpilot hardware! O already integrated the openpilot box into the car harness.
Looks like a car again:
Boxster EV
Has thanked: 57 times
Been thanked: 48 times
Post by Boxster EV »
Impressive how quickly you are bringing this build together. Inspiring stuff.
benr
Has thanked: 4 times
Post by benr »
Did you mount one of the Outlander motors in the reverse orientation of the others? I take it there's no issue running it the other way round?
I'm thinking I might have to do this in my long-planned build.
Zapatero
Post by Zapatero »
Update: Johannes and me had another session and everything works so far. Now i just have to put the batteries in. Unfortunately part 2 of the house renovation is taking up all my time and it'll be another 2-3 weeks until i can work on the subaru again!
Zapatero
Post by Zapatero »
benr wrote: Thu Feb 02, 2023 5:22 pm Did you mount one of the Outlander motors in the reverse orientation of the others? I take it there's no issue running it the other way round?
I don't know yet for sure as i didn't drive it, BUT i still have plan B: Swap 2 cables of the connection between inverter and motor and swap the resolver cables according to it, then it'll spin backwards thinking it's spinning forward. Motor won't even know whats happening 8-)
Zapatero
Post by Zapatero »
Finally, after a battery disaster, i am moving forward with this conversion. I sold the Kona-Battery as the TÜV-Guidelines for building EVs in Germany have been changed while i built this Impreza, saying that an energy storage unit can't be any closer than 400mm to the front end of the bumper and 300mm to the rear end of the bumper. I bought the Leaf-Battery with 40 KwH from Marty from this forum. That Pack is so much easier to install!!!
Yesterday we welded the battery boxes and put half the Pack und the back. The planned watercooling won't work now, but i'm planning on aircooling them.
Tomas
Post by Tomas »
Plenty of space at the front! Very impressive and factory-looking build
elShankos
Has thanked: 29 times
Been thanked: 10 times
Post by elShankos »
Thanks a lot for sharing all this info - super helpful as I'm about to pull the engine out of my Legacy GT (3rd Gen) to build battery boxes up front. Did you do any 3D modelling to plan the space at all? Just curious.
Zapatero
Post by Zapatero »
I'm sad and sorry to tell, but due to personal circumstances i decided to stop this EV-Conversion.
All the Parts will be listed for sale.
AMP3R
Been thanked: 53 times
Post by AMP3R »
Alibro
Been thanked: 221 times
Post by Alibro »
Sorry to hear that as I enjoyed following this build but sometimes life happens and we have to move on.
Good luck and hopefully we will see you back here again sometime.
Pete9008
Has thanked: 102 times
Been thanked: 350 times
Post by Pete9008 »
Sorry to hear that, hope you get everything sorted out.
nkiernan
Has thanked: 385 times
Been thanked: 80 times
Post by nkiernan »
thomaa
Has thanked: 17 times
Been thanked: 6 times
Post by thomaa »
That's a huge shame. Best of luck with life and hope to see you back with some great projects.
Your 86 conversion was brilliant. newbie here but that has put pipe dreams in my head to try the same some day.
Ruudi S
Has thanked: 27 times
Been thanked: 28 times
Post by Ruudi S »
Zapatero wrote: Wed Dec 28, 2022 10:09 pm Successfully tested on the Canbus so far:
Orion BMS
BMW Lim
IBooster Brake
Brake pedal
Cruise Control
Heater control
How did you make the CAN bus working? I'd like to make 2008 diesel Legacy CAN happy, without the engine and make the electric power steering rack turn on.
Did you hack that or your car didn't have those problems?
