Dual BMW Hybrid packs?
- Has thanked: 134 times
- Been thanked: 339 times
Re: Dual BMW Hybrid packs?
Why not? Or perhaps, why not use three for high power and better range?
You will have to decide on how to connect on individual cell/module/pack level. I recommend you draw some diagrams so you can visualize where to put the fuses or pack disconnects...
- lsh3rd
- Has thanked: 117 times
- Been thanked: 40 times
This topic came up on another thread after I asked a question about running more than 6 modules in series for higher voltage. Some users are doing exactly what you are proposing, but the issue is tied to the BMW BMS configuration - you'll probably want to use SimpBMS on these to leverage BMW's factory BMS boards (search this out). The BMS is designed to work with 6 distinct CAN addresses - I believe that the packs can be jumpered to listen on a specific address, but you are limited to 6 choices (Take a look at YouTube user "Good Enuff Garage" - he did several videos on this IIRC). Essentially you will probably need to use a CAN bridge with offset addresses. This should give you an idea of what to search on - I think more extensive answers probably lie in other threads. Hopefully this is enough to get you to the next level.
- Has thanked: 8 times
- Been thanked: 47 times
or use separate can channels on a Teensy i guess would work.
E46 touring
BMW 9kwh & 12kwh packs
I currently am running 18 modules 6s3p paralleled at the cell level via cell taps and module level, each parallel set of 3 modules share 1 bms, currently working on designing some simple plugin pcbs with fuseable links, but I’ve run without them for 2 years, probably time to do something about that right….
When I built this I was completely reliant on existing code, I would probably follow a different route now…
