As it is not shrink fit i would advise against glueing. I think your best bet would be to bevel the larger shaft edge on a lath and drill two 8mm holes into larger shaft spread some 10cm apart 90deg shifted relative to each other.johu wrote: ↑Sun Aug 07, 2022 12:02 pm That didn't work too well... The handbrake is all crusty and won't release and was stronger than the glue. Car was still on ramps. I knew what would happen - at some point the ramps just shot forward. Just didn't expect them to puncture my Loctite cleaner bottle
No gotta get the whole thing out, clean it properly and glue again. If it don't hold up get a driveshaft made
Then find a good welder who can make a circumference weld first and then fill both spot welds.
Then you would need to put your shaft to lathe to balance it; or you can fit a rubber damper to it... they used to do that in the past for dynamic balancing and it works somewhat
You could also temper the shaft at 400deg or similar for some time to relieve straess of welding... technically correct term is normalizing
