Can you share your code for that? I'm thinking of going in a completely different direction of sending certain parameters to an Arduino over CAN and then sending different values over Throt2 to implement cruise.
GS450H Discussion
- PatrcioEV-ATX
- Has thanked: 42 times
- Been thanked: 67 times
Re: GS450H Discussion
2012 Nissan Leaf (sold)
2016 Mercedes B250e (sold)
2023 Volvo C40
2023 Volvo C40
- konstantin8818
- Has thanked: 2 times
- Been thanked: 10 times
Test sample of the ring for permanently locking the high range was cut from PVC plastic. Laser wasn't really accurate(cheap model for advertisement production) and burned a little too much into the ring, but measurements seems to be taken correctly, so here dxf file for those who interested. You need to make a 32mm pack of this rings, preferably from some sort of 2-3mm thick stainless steel. Or make half of them and replace only rings with outer teeth.
xp677
- Been thanked: 15 times
Hi, yes I can, note that it is not for Damiens VCU, it's for my own board which the VCU was later based off. But the differences should be obvious.PatrcioEV-ATX wrote: ↑Mon Oct 04, 2021 3:28 pmCan you share your code for that? I'm thinking of going in a completely different direction of sending certain parameters to an Arduino over CAN and then sending different values over Throt2 to implement cruise.
- PatrcioEV-ATX
Much appreciated! This is almost exactly the direction I was working towards - just better. You have a lot more safety checks built in to your programming too.xp677 wrote: ↑Wed Oct 06, 2021 2:37 pmHi, yes I can, note that it is not for Damiens VCU, it's for my own board which the VCU was later based off. But the differences should be obvious.PatrcioEV-ATX wrote: ↑Mon Oct 04, 2021 3:28 pmCan you share your code for that? I'm thinking of going in a completely different direction of sending certain parameters to an Arduino over CAN and then sending different values over Throt2 to implement cruise.
2023 Volvo C40
2023 Volvo C40
What is the reason that the external electric pump is needed when the internal mechanical pump works driven by MG2? Or is the driveshaft not locked in this video and is the mechanical pump only driven by MG2 because the input shaft will also rotate when MG2 spins? Or something else?Jack Bauer wrote: ↑Thu Sep 10, 2020 4:59 pm Someone needs to just give it a shot (won't be me sorry!).
For those interested in oil pressure here's one from the back catalog :
- ZooKeeper
- Has thanked: 8 times
- Been thanked: 5 times
The mechanical oil pump is driven by the input shaft, so if that is locked (as required to get motive tq from MG1), there would be no fluid available to the transmission for lubrication.
Damien goes into great detail in the video below (~55-60 minutes in for the lube pumps)
Time for ICE Melt
Yes that was what I understood, but then I saw that video where Damien said it was driven by MG2 so I was a bit confused. However, I now see the video is much older than the post it was embedded in. So I guess the input shaft wasn't locked there so the side effect of turning MG2 was also turning the input shaft and with that the internal oil pump.ZooKeeper wrote: ↑Fri Oct 15, 2021 8:10 pmThe mechanical oil pump is driven by the input shaft, so if that is locked (as required to get motive tq from MG1), there would be no fluid available to the transmission for lubrication.
Sorry for my confusion, I should have opened the video and check the date.
- ggeter
- Has thanked: 4 times
- Been thanked: 28 times
Dumb question, and sorry if already answered, but if mg1 not locked up, can one use mg2 for power and let mg1 pump?
Houston, Texas, USA
EV Newbie
IT Consultant
EV Newbie
IT Consultant
If I'm right, the mechanical pump is connected to the ring gear (green) of MG1. If the engine (blue) is locked and MG1 (yellow) turns, then the ring gear will turn and I would say the mechanical pump would also turn. But I think the pro's here can give the correct answer.
I'm not right
- catphish
- Has thanked: 99 times
- Been thanked: 197 times
I am looking at programming ratio shifting on the GS450H and I'm trying to understand the relationship between the following:
* High and low ratio
* Brake 1 and Brake 2
* Solenoid 1 and Solenoid 2
Specifically, does anyone know which solenoid(s) should be energized for low ratio, and which for high ratio? Once I know this, I'm hoping I can get the correct timing for smooth shifts.
Edit: I just realised this is actually the original question of this thread, but I'm not sure that it was answered with any certainty.
This diagram leads me to believe that only one solenoid should be engaged, but several others seem to be operating them as a pair. It would be great if anyone could clear up my confusion here.
- konstantin8818
Watch my post at previous page. Mechanical pump connected to blue part, wich is ICE input. If you go same way as Damien, locking up input shaft, then you need external oil pump. I'm now at process of locking planetary carrier, to use original mechanical oil pump. Only one issue is it won't work while in reverse, so I need to lock mechanically one of the gear ranges.Markos wrote: ↑Sat Oct 16, 2021 12:45 pm If I'm right, the mechanical pump is connected to the ring gear (green) of MG1. If the engine (blue) is locked and MG1 (yellow) turns, then the ring gear will turn and I would say the mechanical pump would also turn. But I think the pro's here can give the correct answer.
- NiHaoMike
It looks like if the ring gears are welded in place, MG1 would have a direct coupling to the wheels allowing MG1 to provide reverse.
- konstantin8818
This somehow passed by my head at the first place
However I don't want any additional electrinics to work inside my gearbox and high range seems to be enough for lightweight vehicle, so I'll stay with locking ring, atleast for testing purpose.
- NiHaoMike
Might it be possible to use a fuel pump as the electric oil pump?
- konstantin8818
I believe ATF is not good for every type of pumps. This fuel pump also has to be high pressure, 100psi = 6.8 bar.
Anyway, only real time testing will say if it any good.
- ZooKeeper
Diesel, gasoline and ATF are all very similar in terms of pumping, I have used "fuel" pumps to pump all three fluid types with great success.
If we are not "shifting" between high and low, not much pressure should be needed for forced lube, although certainly designed to have it.
Time for ICE Melt
- Gregski
- Has thanked: 631 times
- Been thanked: 1607 times
I skimmed this thread and did not catch the part numbers for the Engine/Transmission harness so I would like to share what I have recently learned when buying mine, I hope you don't mind, I also would like to share a link to me going through the detailed steps of "thinning" it out which I posted on the DIY Electric Car forum (I am still a little bit intimidated to post here on the accounts of lack of smarts and all, ha ha) 1971 GMCe Lexus GS450H BMW 530e Tesla Model S powered Electruck
ok so a little background, my transmission and inverted are both from the same 2010 Lexus GS450H, and this harness is from a 2008
now check this out and you tell me if this makes any sense to you guys:
Part Name: Engine Wire
Harness Part # 82121-30E21 is for 2007-2010 (this is the one I bought)
$1,369 at the local Stealership
Harness Part # 82121-30E22 is for 2009-2011 (based on my VIN I actually need this one, but the other plugs in to the transmission just fine)
$1,366 at the local Stealership
the large rectangular plugs on this harness plug into the Engine Control Module ECM / Hybrid Vehicle Control ECU which appears to be one and the same small metal box with two connectors on it
as mentioned before by some others, this harness does NOT include the INVERTER plug, that plug comes on a different harness, this harness actually directly plugs into the other harness, I have that information as well, but one thing at a time
and here it is all thinned out to just the sections we need
- PatrcioEV-ATX
Nice! Looks like yours includes the VSS connector too. That could be helpful depending on how you plan to drive your speedo/odo. Yeah, I nearly sliced the end of my thumb off getting down to the simple, bare necessities on that harness! It's now numb on the very tip. I don't think anyone has found the harness with the inverter plug (I could be wrong), so great if you have that PN. My local Lexus dealership couldn't find it. Fortunately, my inverter came with it attached!Gregski wrote: ↑Sat Oct 30, 2021 4:53 pm I skimmed this thread and did not catch the part numbers for the Engine/Transmission harness so I would like to share what I have recently learned when buying mine, I hope you don't mind, I also would like to share a link to me going through the detailed steps of "thinning" it out which I posted on the DIY Electric Car forum (I am still a little bit intimidated to post here on the accounts of lack of smarts and all, ha ha) 1971 GMCe Lexus GS450H BMW 530e Tesla Model S powered Electruck
2023 Volvo C40
2023 Volvo C40
- Gregski
Yes I fully intend to try to do something with the VSS signal in terms of a speedo especially since I am converting a 1971 GMC/Chevy truck, I was planning on converting the Damien VCU MG1 Speed gauge to a Speedometer as I really don't care how fast MG1 is spinning, but I have no idea how to do it yet, I have a companion thread called Any Isabellenhütte IVT-S Ninjas on here? where I am making a fool of myself trying to figure out how to do just thatPatrcioEV-ATX wrote: ↑Sun Oct 31, 2021 6:11 pm Nice! Looks like yours includes the VSS connector too. That could be helpful depending on how you plan to drive your speedo/odo. Yeah, I nearly sliced the end of my thumb off getting down to the simple, bare necessities on that harness! It's now numb on the very tip. I don't think anyone has found the harness with the inverter plug (I could be wrong), so great if you have that PN. My local Lexus dealership couldn't find it. Fortunately, my inverter came with it attached!
- Gregski
in the diagram below the TEAL harness is the Inverter Harness and the OLIVE harness is the Transmission harness the arrow points to how and where they plug in directly into each other (no intermediate box involved)
their proper names are:
Engine Room Main Wire - this is the Inverter harness
Engine Wire - which is the engine and transmission harness that we need and has the part numbers I listed in the previous post this harness has two rectangular plugs of which the larger one plugs into the Engine Control Module ECM, and a smaller one plugs in to the same box but they call that plug Hybrid Vehicle Control ECU
- konstantin8818
I've fabricated that locking ring for high range, I've shared here before, from solid piece of aluminum.
It fits like a glove.
- ggeter
Mother of god... When my pump fails, I'll be reaching out... Watching the space very closely.
Houston, Texas, USA
EV Newbie
IT Consultant
EV Newbie
IT Consultant
- Gregski
this is the Inverter harness, officially called Engine Room Main Wire part numbers:
82111-30K62 fits 2008-2009
costs $7,144 new
82111-30K64 fits 2010
costs $6,341 new
The Resolver plugs from the transmission harness plug in directly into the Inverter harness like so
if you can prevent the seller from just cutting off the pig tail and get them to unwrap about 18" away from the Inverter plug then the Resolver plugs come with the Inverter plug like so
and if you unwrap just a little more you won't cut the brown wires that simply loop back on themselves, so the actual remaining Inverter Plug wiring is not that much that runs to the Hybrid Vehicle Control ECU larger plug.
the full anatomy of this harness can be viewed here: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S powered Electruck
costs $7,144 new
costs $6,341 new
- ZooKeeper
SWEET! I am certain this is superior to my (alternate) plan of just filling that space with J-B Weldkonstantin8818 wrote: ↑Wed Nov 03, 2021 1:08 pm I've fabricated that locking ring for high range, I've shared here before, from solid piece of aluminum.
It fits like a glove.![]()
Time for ICE Melt
- konstantin8818
I just had an option of milling this part for free. It is less costly to cut those from 2mm stainless steel with laser and replace only metal clutch rings.
Atleast now I'm absolutely certain that this part will fit where it belongs.
