Sub-station 1
rikohm
Sub-station 1
Post by rikohm »
Subaru Outback powered by one of those Enova kit's that circulated some years ago.
Bought the car with the engine in pieces.. well except the engines two block half's and the crankshaft that had become one solid piece.
Most of the engine were in shoeboxes in the boot so extraction was easy ;)
Calipers and ruler get's you a long way...
But some times not long enough. Masonite is a bit cheaper to mess up than 40mm alu.
The only part that i didn't get (and hade some use of) from the diesel engine were the clutch, so i got clutch centers from a racing site.
Also for reference, Volvo S80 clutch, perfect fit on the Enova / Hyundai splines.
S80 clutch
S80 clutch
The Enova box is big.
Enova box
Enova box
I'm letting the original ECU believe it still in charge. So i have to keep it happy.. Throttle valve, EGR, massflow, fuel pressure valve and turbo boost valve now lives under the stereo.
Fuel temp, fuel level, fuel pressure, air temp and some more are simulated with resistors.
Crankshaft and camshaft is simulated with an arduino nano and ardustim. Locked on 1800rpm, keeps ABS and power steering happy.
rikohm
Sub-station 1
Post by rikohm »
First test run was made on prius gen "0" cells, ≈20year old.
Spare wheel well had to go. Rear battery box. 54s 60ah winston thundersky
tripple glacing
tripple glacing
Safety disconnect..
Front battery box. 30s 60ah winston thundersky
Enova box is cut down, just not enough room.
rikohm
Re: Sub-station 1
Post by rikohm »
Remember to tighten your connections..
Final weight
Should'n it be some thermal grease under these :?
Re: Sub-station 1
Awesome, nice craftsmanship and good pictures - thanks :)
rikohm
Re: Sub-station 1
Post by rikohm »
Thank you.
I managed to clear out the last administrative wrinkle this morning. Now it's officially electric.
pm_dawn
Re: Sub-station 1
Post by pm_dawn »
Hi !
Is this the two Sub that was on blocket like two months ago for cheap ?
Like 2009MY or something ?
I was looking at them thinking It would be a interesting build.
But I already have a couple of projects....
So I passed on them.
REally nice builds !!
Fun to see some more conversions in Sweden.
Mvh
/Per
rikohm
Re: Sub-station 1
Post by rikohm »
I bought Sub-station 1 in February in Arvidsjaur, indeed from Blocket, it's a 09.
Sub-station 2 is not my own, i'm only helping out with the conversion but it's a 09.
They pop up everywhere, ≈1000€ some times half of that.
It's mostly 2008 and 2009 some 2010, and rumour says even 2011. All diesel.
rikohm
Re: Sub-station 1
Post by rikohm »
Fitted a new encoder to my enova motor today. Have had some problem with dust blocking either the slots in the encoder disk or the sensor itself. Have blown it out with compressed air to some success previously but two weeks ago it didn't clear the problem anymore.
I will probably go with aber333's route, with a shaft mounted plate, in the future. This one will be problematic to weather proof.
8000km so far..
Ruudi S
Has thanked: 67 times
Been thanked: 32 times
Re: Sub-station 1
Post by Ruudi S »
rikohm wrote: Wed Sep 18, 2019 8:29 pm
Do you have the gearbox CAD drawing?
Ruudi S
Re: Sub-station 1
Post by Ruudi S »
rikohm wrote: Wed Sep 18, 2019 8:29 pm I'm letting the original ECU believe it still in charge. So i have to keep it happy.. Throttle valve, EGR, massflow, fuel pressure valve and turbo boost valve now lives under the stereo.
Great work!
So you kept the diesel engine ECU on board and working.
Does it need both crankshaft and camshaft singals? Does just pulses do the job?
