Locked
canadasconvert
Been thanked: 8 times
Post by canadasconvert »
Thanks you very much. I have been following your build over the past year. I have an 02 Boxster 'S'. I will look at Jon Volk's tweaking as well.
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Post by Boxster EV »
canadasconvert wrote: Thu Jun 17, 2021 4:52 pm Thanks you very much. I have been following your build over the past year. I have an 02 Boxster 'S'. I will look at Jon Volk's tweaking as well.
Motor Params here:
Boxster Params.json
(1.45 KiB) Downloaded 495 times
Link to the modded firmware here. Use the .bin file.
Jackk
Post by Jackk »
What are people using to spin up motor for bench test...I've opted for a 60v power supply...max 5 amp output. The motor wants to spin but barely moves...
What sort of current draw is there to get it to spin? Is it I don't have enough power or am I having encoder issues...
Boxster EV
Likely to need more than 5 amps.
You can then carefully check the encoder is wired correctly.
muehlpower
Been thanked: 186 times
Post by muehlpower »
Jackk wrote: Wed Jul 14, 2021 9:14 pm What are people using to spin up motor for bench test...I've opted for a 60v power supply...max 5 amp output. The motor wants to spin but barely moves...
I use 4 12V car batteries in series that are fused with 30A. The limit for the drive unit is set to 20A.
rjmcdermott81
Post by rjmcdermott81 »
I used 4 car batteries as well. I also echo Boxster EVs comment. My encoder plug wasn't fully contacting and it was causing issues. You can test to see if it's getting a signal by plotting some values and turning it by hand. (sorry I don't recall the specifics but they are further up in the thread).
Lowcoe
Post by Lowcoe »
Hello all. Regrettably I have a question. Test fire stalled at getting positive contactor to engage. I’ve read everything many times. Sorry for this but I’m stumped.
I have 4 tesla modules in series for 95 v. Test settings as follows from reading all posts.
Udc nom 95
Occurlim toggled from neg to pos and back
Udc min 0
Udc max 100
Throttle pot : dual channel
Idle mode off
Udc sw 85
Contractor trip : precharge on changed from default
These are listed in order they fall on page. All others are defaults.
Error message reads
[18] stop- over voltage
If nothing is obvious I probably need to pull the motor and check solder contacts as this was my first attempt at fine soldering
Thanks in advance. Apologies for my ignorance
Boxster EV
Lowcoe wrote: Sat Jul 24, 2021 8:08 pm Hello all. Regrettably I have a question. Test fire stalled at getting positive contactor to engage. I’ve read everything many times. Sorry for this but I’m stumped.
Udc nom 95
Udc min 0
Udc max 100
Idle mode off
Udc sw 85
Error message reads
Please post a full list of your parameters.
What firmware are you using? Have you tried a known good LDU version like this (.bin):
viewtopic.php?p=26478#p26478
Lowcoe
Post by Lowcoe »
Thanks for your time.
I uploaded the latest version 5.00-R-sine
I tried to open those files but no luck. Do I just upload those to the program? Again I apologize for my inexperience…
Boxster EV
Look at UDCSW. It’s not been lowered so main contactor won’t close. Try that first and make sure you save. After testing, put the settings back.
I think most people are still running the LDU firmware I mentioned in my last post. I’d suggest you try it as it’s known good. Click on the .bin file, save as to your PC. Then go to the inverter firmware field and upload it.
Lowcoe
Post by Lowcoe »
Thanks. Never hit save before. Setting to 85 yields no change. Attempted to upload file. All of a sudden WiFi link is unstable/ unreachable. Despite using different computers and different browsers the interface shows the dreaded spinning dots in a roundabout…. Frozen….
Boxster EV
Lowcoe wrote: Sun Jul 25, 2021 8:40 pm Thanks. Never hit save before. Setting to 85 yields no change. Attempted to upload file. All of a sudden WiFi link is unstable/ unreachable. Despite using different computers and different browsers the interface shows the dreaded spinning dots in a roundabout…. Frozen….
Need to get your PC right next to the inverter cover for stable WiFi.
muehlpower
have you tried these settings on your PC?
viewtopic.php?p=29453#p29453
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 352 times
Post by P.S.Mangelsdorf »
Check out this thread
viewtopic.php?f=5&t=1756
Lowcoe
Post by Lowcoe »
I think deleting all the files is the right tack but coding ain’t my thing. It says curl … not sure how to execute that..
Isaac96
Post by Isaac96 »
Are you on windows? Open up a command prompt (windows search bar) then paste the command in there.
Lowcoe
Post by Lowcoe »
I got to the “curl help” page but delete doesn’t seem to be an option.
Isaac96
Post by Isaac96 »
Curl just sends messages or files to a specified URL. In this case, it's sending "DELETE" to the 192.168.4.1 page.
Been thanked: 1914 times
If you're on windows you need to download the curl executable here: https://curl.se/windows/
Clanarn
Post by Clanarn »
I ran into some problems with the LDU after a 2mins test driving on the street. I think we did 10kmh maximum. It has worked flawlessly on the bench with 400v. The cooling wasn't working during test drive.
After the test drive car was powered off. 1min after we turned it on again but this time the following accured and has been happening ever since: Press start, main contactor closes for 1 sec, then opens again. Overcurrent is displayed as error.
50% of the time it actually goes in run but when throttle is applied it immediately blows the battery fuse. (400A fuse). Im testing with a 80v battery with a 30a fuse now. No need the blow more 400A fuses than necessary=).
Is there anything else I can do before disassembling motor from inverter to ohm-measure the igbts?
Clanarn
Post by Clanarn »
fredd90
Post by fredd90 »
Clanarn wrote: Fri Aug 27, 2021 9:28 pm Hi,
Hello
Did you have readings of inverter and engine temp?
I have experimented with pwm controlled pumps, when driving at aprox 50km/h there is som heat produced, not mutch but with no active cooling you have some real problems i guess =(
Dont know what brand of fuse you using, but short therm load can be 3-5 times greater than rated current.
When you describe your problem it sounds that a row of positive or negative igbt is shorted to ground or positive.
Boxster EV
I’d be surprised if you damaged the inverter on such a short run with no cooling. Be interested to see what your max temp settings for motor and inverter are.
Sounds more like something is loose on the board, although that doesn’t explain why you’re blowing fuses.
Clanarn
Post by Clanarn »
Motor was 25°C and inverter 47°C. Max setting 100°C for both. I can see how a row of positive or negative igbt could be shorted to ground or positive. That would explain it. Boxster EV- I will inspect the board when dissembling it.
From reading this thread and I understand that the IGBTs can get damaged but not immidently "die" from back EMF. However, the test drive went fine and I have never had the contractors open on it when running.
Fredd90 - Ive used a ferraz fuse.
Check IGBTs
Put multimeter in diode mode.
Positive lead on B-, negative on the 3 phases. Should read 0.3V. When seeing 0V you found a shorted phase leg to GND. Other way around to check positive.
Locked
