encoder AB Topic is solved
chentron
Has thanked: 42 times
Been thanked: 10 times
encoder AB
Post by chentron »
I have a motor (AZD AC24LS) with a skf built-in encoder AB , 64 pulses , 4 cables:
https://mega.nz/file/okwTnAgT#aIGrPZF0U ... 3B9WDDptLA
After reading and searching forum , i think i must choose parameter motor in software " encmode=1 " (quadrature).
But I have not clear where to connect my 4 cables.
mainboard johannes have 3 pin (1, 2, 3) for encoder
Please could somebody help me . thanks
Has thanked: 380 times
Been thanked: 1568 times
Re: encoder AB
https://openinverter.org/wiki/Main_Board_Version_3
GND to GND
A to ENC_IN_A
B to ENC_IN_B
5V to ENC_5V and replace R11 by a zero ohm resistor or solder bridge.
chentron
Re: encoder AB
Post by chentron »
thanks johu, but i forget to say i have mainboard ver.2 , and now that it is populated it is not easy to see.
Is there a resistor in this version to replace or bridge ?
Re: encoder AB
https://openinverter.org/wiki/Main_Board_Version_2
Then it is R7 , forth from the bottom above the 16-pin header.
