Jack Bauer wrote: ↑Mon Dec 21, 2020 9:26 am
Keep up the good work Matt:)
Thanks.
If all goes well I should have more for you to test second week of January. Things need cleaning up. I at least did put in the state transitions like with the CHAdeMO EVSE. In terms of a hack / refine phase, we're definitely in the hack state.
So some clarifications... This connector is the one I unplugged and left the power on with:
The green wire is ground, and the white with purple is pilot. This connects to CAN Low (Ground), and CAN High (Pilot).
This then results in:
And my table still looks reasonable:
I did get it to work in Linux using my ValueCAN3. The key is the drivers basically just use the hardware config and can't modify it on the fly. So I booted into Windows, set CAN 1 to 500k and normal mode, and set CAN 2 to 33.3k and silent mode. Now I can capture in SavvyCAN and analyze in Vehicle Spy.
I did not get far with figuring out what causes the Fast Charge limits to be calculated as they are, but I did figure some things out. I think there's about 30 signals, and I figured out about 13 of them, including all the CHAdeMO ones. The others are harder. There's three multiplexed ones that I have no idea what's going on with them.
Not sure how much I'll do tomorrow, I'll probably do some stuff in the morning but the afternoon is busy.
-Matt
