Lexus Inverter Hacking
Teknomadix
Re: Lexus Inverter Hacking
Post by Teknomadix »
Jack Bauer wrote: Thu Jun 20, 2019 6:31 pm I think the MGR with a little 12v oil pump and cooler would make an excellent low cost drive unit.
Starting a new thread to focus on the MGR viewtopic.php?f=14&t=190
dso
Post by dso »
How did you manage to remove the capacitor section from the gs450h inverter? It seems very well attached with the silicone, and I don't want to crack it.
Has thanked: 10 times
Been thanked: 334 times
It's not silicone it pu adhesive. Start at one corner with a thin screwdriver. Be slow as you want to let the pu break the bond. See WeberAuto videos on youtube for more detail on the type of adhesives toyota use.
dso
Post by dso »
Thanks for the advice. I got it open successfully.
I took some photos of the inverter control board if anyone is interested. https://imgur.com/a/z4XYsMP
I am also an electronic engineer, so if I can help with developing a board for the GS450H let me know.
dso wrote: Mon Jul 15, 2019 8:23 pm
That would be much appreciated. I'm snowed under with projects.
sfk
Post by sfk »
Oh very much yes please!
dso
Post by dso »
I found the project log of the BMW with the GS450H posted earlier.
https://hackaday.io/project/4649-diy-el ... cled-parts
I think there is some useful information there.
sfk
Post by sfk »
Trouble is, he's deliberately left out all the useful information. >:(
Teknomadix
sfk wrote: Fri Jul 19, 2019 12:14 am Trouble is, he's deliberately left out all the useful information. >:(
Hmmm.. can't agree with that statement, because there is in fact a lot of useful information in the pages of mauswerkz E46 HaD project; for example: https://hackaday.io/project/4649/logs?s ... est&page=4
At one point about three years ago exactly Vincent (mauswerkz) was considering an open-source release of his work. But it seems source design and code files have yet to be released. Possibly an invitation to join the discussion here would be well received? The fellow is quite easy to contact via an internet search.
sfk
Post by sfk »
Sorry. Didn't mean to offend.
Vincent would be a great asset.
I got the impression he'd moved on from this sort of stuff.
All the more reason to release it and save duplication of effort.
Kevin Sharpe
Been thanked: 8 times
Post by Kevin Sharpe »
Jack Bauer wrote: Fri Jul 19, 2019 10:09 am All the more reason to release it and save duplication of effort.
Wouldn't that be nice 8-)
Teknomadix
removed
I sent him a pm on diyelectriccar forum when i was getting started on this. No response to date.
I have worked out most of whats needed to design a logic board and I will get to it just snowed under.
johnspark
Has thanked: 59 times
Been thanked: 48 times
Post by johnspark »
i intend getting voltages off of the DC/DC connector off the side of the inverter when i get a chance with either voltmeters and or with a picoscope. I have a Toyota Camry Hybrid 2012 on the lawn to test with. Will submit oscillographs here when i can.
I have just picoscoped either NODD pin 21 or VLO pin 11 of Power Management Control ECU and got the following mark space oscillogram. I think i have the wrong polarity. I could not tell because i did this work when it was nearly dark. will try to get more waveforms in next few days.
Teknomadix
removed
Teknomadix
removed
I'll dig out my notes and post on here.
johnspark
Post by johnspark »
Teknomadix wrote: Mon Jul 22, 2019 9:57 am
johnspark wrote: Sun Jul 21, 2019 7:33 am Toyota Camry Hybrid 2012
Is that the same inverter as the Lexus?
it is apparently similar to a is300h inverter.
Here are some pictures from my notes. Please excuse my scribbles:) Will put something more sensible together asap.
Has thanked: 134 times
Been thanked: 335 times
Jack Bauer wrote: Sun Apr 28, 2019 9:07 am These Toyota inverters are a huge untapped resource. I just wish I had the skills and finance to make it happen quicker.
In the same vein it is of course impossible to kill the booster. No turning on both high and low , no running the pwm freq too high too low or too much or too little duty.
Does the booster shut off if you connect 360Vdc for the battery? Like does it have some overvoltage protection? I tried to connect 360Vdc but cant really find anything helpfull untill i get your breakaway board.
A
xp677
Been thanked: 15 times
Post by xp677 »
We're going back in time a bit here, but following from this video:
How did you manage to enable the converter here? I've tried inputting PWM to what I believe to be the gate driver inputs of the converter PCB (the control board that lives in the converter housing), but I don't get a response. Do you have any info on this unit? Been pulling my hair out for 2 days so far on this!
Do you have any notes on the connections you made to this unit?
Yep I have notes and pictures. Give me a day or two and I'll post up here.
xp677
Post by xp677 »
Thanks Damien. Were you able to find these? I've got a provisional controller and code for this converter now, its just connecting it up that I'm struggling with.
Swing
Has thanked: 19 times
Been thanked: 11 times
Post by Swing »
I thought you guys were purposely bypassing the boost converter as it would be to limited in power, and work with a battery with a higher total voltage.
I should do more reading and watching all the videos I guess.
