The Blue Yacht : E39 + Lexus MGR
Been thanked: 1116 times
mappleton
Re: The Blue Yacht : E39 + Lexus MGR
Post by mappleton »
I'm excited about this project and looking forward to seeing how the car performs. Thanks for all your hard work Damien!
Has thanked: 478 times
Been thanked: 308 times
Post by MattsAwesomeStuff »
Just reposting what I wrote in the MGR thread....
Sweet! An MGR Project. I don't know if I've ever actually seen one.
The MGR is my backup plan for whey my 260lb forklift motor --> transmission --> old differential just doesn't work properly. It's also maybe my plan for the front part of AWD.
Can't wait to see more on this.
But wait... the criticism!
"This will never hold. It's not designed to be used for more than 0.8 seconds or it will turn into the fires of Mordor!"
I dunno, maybe it melts, maybe it's fine. I really really really want to find out just how badly it may or may not need some limited cooling.
Ruudi S
Has thanked: 67 times
Been thanked: 32 times
Post by Ruudi S »
Good work! I have a question about this motor, what do you think is it possible to put two of those motors to left and right rear axle? Would they fit side by side for example to 300 series rear axle? I thought to lock the differentials and so we could get better traction, then open diff, in slippery conditions.
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
Ruudi S wrote: Tue Sep 08, 2020 12:57 pm do you think is it possible to put two of those motors to left and right rear axle?
Sure :)
Ruudi S wrote: Tue Sep 08, 2020 12:57 pm Would they fit side by side for example to 300 series rear axle?
You'll need to confirm that and look at the impact on the body shell. The good news is they are very cheap so it's easy to buy one and try it 8-)
We have ignition:) Video soon.
Been thanked: 411 times
Jack Bauer wrote: Tue Sep 29, 2020 1:22 pm We have ignition:) Video soon.
OMG Damien! You are doing it wrong....driveshafts...argh...!
No seriously, that was my alternative plan in case the shaft would be too hard to drill. To cut a triangle splice into the shaft and weld it there. Of course i planned doing it in the lathe. Did you at least put a pin inside both shaft holes?
I cant wait to see the video.
A
TheSilverBuick
Post by TheSilverBuick »
So much awesome. Been catching the highlights on twitter.
So I found a potential source of connectors for the MGR. I happened to have 3 Gen 2 prius battery to inverter plugs. Massaged off the plastic with a mallet and got 3 nice large connectors that fit the MGR terminals perfectly. Wouldn't be surprised if they were the same part.
ZooKeeper
Has thanked: 8 times
Post by ZooKeeper »
Jack Bauer wrote: Wed Sep 30, 2020 7:06 am So I found a potential source of connectors for the MGR. I happened to have 3 Gen 2 prius battery to inverter plugs. Massaged off the plastic with a mallet and got 3 nice large connectors that fit the MGR terminals perfectly. Wouldn't be surprised if they were the same part.
THANKS! I was wondering what to use and didn't even think of that. Worst part is that my HV cable is laying there coiled up next to the bench.... :)
Time for ICE Melt
TheSilverBuick
There's two gen2 Prius's that hit the local salvage yard two weeks ago, maybe I'll go harvest those connectors....
konstantin8818
Post by konstantin8818 »
I've tried to just pull Lexus cables out of inverter side plug and insert them into prius's inverter side plug, but they won't fit. Terminals profile and lenght are different, as well as latching hole size. Cable diameter is also slightly different - when I pulled prius sealant rubber on Lexus cable, it ripped.
mattndex@gmail.com
Post by mattndex@gmail.com »
Tuned in and hoping for an update. This project has a lot of potential if it succeeds.
As you folks know I hate warm and dry climates so I spent a few hours rolling around on the tarmac today until I got soaked and cold. Ahhh so refreshing :D Anyway subframe is back in the car, only needed a small bit of cutting to accomodate the mods but wow did my favorite automaker ever build a car as tough as the E39! Back to base soon and we'll see about making those wheels turn.
Progress:)
ZooKeeper
Post by ZooKeeper »
NICE! At least it looks like it is Sunny and Dry, not too sure that 12c counts as warm though!
Time for ICE Melt
Ctwidle
Been thanked: 12 times
Post by Ctwidle »
Thank you Damien! This is like an early Xmas present for my VW project. It’s tempting to hop in and copy but I know that with my limited knowledge and experience I have to be patient and wait to see it driven by a zombie!
Chris
Folks I'd just like to announce that due to impending life changes for me this project has been handed off to forum member paaa who will be continuing the build and updating the thread.
paaa
Been thanked: 13 times
Post by paaa »
I will indeed, First task was to get the car wired up to roll it off the transporter. For this I made use of 3 of the now infamous valence 18v batteries and a Nissan Leaf contactor box a spdt switch , and a small 12v battery I had handy. The only goal in this was to move car off trailer. I did have some fun parking the car out of the way. Before anything is said , car has handbrake half on and 12v supply gets disconnected if cable to throttle gets tight https://photos.app.goo.gl/ioT52UTaCcQovBBi6
mjc506
Has thanked: 30 times
Been thanked: 29 times
Post by mjc506 »
Remote control BMW :)
paaa
Post by paaa »
Exactly why push when you can drive it remotely.
mjc506
Post by mjc506 »
I don't suppose remote steering is next on the list? haha
Glad someone's continuing the project now Damien is (I assume) swanning off to Lanzarote :)
ZooKeeper
Post by ZooKeeper »
That throttle pedal looks familiar ;)
54v moving a comparatively heavy modern BMW with it's handbrake partially on, makes me all the more confident that 240ish volts could get the job done in the VOLTswagen Squareback :D
Time for ICE Melt
Cookie6000
Has thanked: 12 times
Been thanked: 33 times
Post by Cookie6000 »
paaa wrote: Mon Apr 12, 2021 8:06 pm Exactly why push when you can drive it remotely.
Ha! That is a fantastic way to shift the metal around. Good man taking these on. Look forward to the updates.
