GS450H Discussion
wovenrovings
Has thanked: 6 times
Re: GS450H Discussion
Post by wovenrovings »
Yes I saw that on the wiki but I don't think a GS350h actually exists.. so it might be a typo.
And I have searched everywhere but all I can see is a mention of Damien saying he will try one, one day. So was just hopeful that there was something I had missed.
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
wovenrovings wrote: Mon Sep 07, 2020 9:04 am Yes I saw that on the wiki but I don't think a GS350h actually exists.. so it might be a typo.
No idea...
wovenrovings wrote: Mon Sep 07, 2020 9:04 am And I have searched everywhere but all I can see is a mention of Damien saying he will try one, one day. So was just hopeful that there was something I had missed.
BEXUS is using the GS450H transaxle and inverter. If you have a look at some of the development videos you might find an answer to your question. I'll also try and find the inverter part number on LEXI when I'm at the workshop :)
Kevin Sharpe
Kevin Sharpe wrote: Mon Sep 07, 2020 9:54 am I'll also try and find the inverter part number on LEXI when I'm at the workshop :)
Here is the label from our GS450H (2006 car iirc);
xp677
Been thanked: 15 times
Post by xp677 »
Kevin Sharpe wrote: Sun Sep 06, 2020 10:11 am
wovenrovings wrote: Sun Sep 06, 2020 7:19 am There is a 2013 gs450h coming up for salvage auction near me. Has anyone here had a go at hacking the inverters in these?
Please read through the forum, wiki and review the SuperYacht ('BEXUS') project;
viewtopic.php?f=11&t=96
Edit: a search on the wiki says the G92A030020 is from a GS350H not a GS450H
2012+ GS is a different generation, with a different inverter.
No current work done on the control side of this. Likely same hardware as the Gen 1 GSh, but different data packets. Best to buy the whole car and pull the data yourself.
TFirenza
Post by TFirenza »
does anyone have experience with G9201-30010 its a 2008 RHD gs450h , its from the same period so I wouldn't expect it to be an issue but it also isn't listed on the hardware wiki.
wovenrovings
Thanks xp677, exactly what I was looking for. :)
xp677
Post by xp677 »
TFirenza wrote: Tue Sep 08, 2020 9:00 am does anyone have experience with G9201-30010 its a 2008 RHD gs450h , its from the same period so I wouldn't expect it to be an issue but it also isn't listed on the hardware wiki.
As far as we know, all the "square" inverters from the Gen1 GS450h/Camry are the same when it comes to control.
The Camry inverters have different connectors, the LHD inverters have the ports on the other side (mirrored casing), but when it comes to using them, they are all the same.
I've ran both a 2006 and a 2010 RHD GS450h inverter, no issues.
TFirenza
Post by TFirenza »
okay thankyou, I had a hunch that might be the case
AlexD
Post by AlexD »
Im currently shopping around for a setup, having got a few prices back from some places, it seems one of the big costs is the Oil Pump, has anyone successfully used another more general purpose pump? I could easily mill an adaptor plate to fit the transmission.
Been thanked: 1122 times
If you do then please share the design.
You could try one of these : https://www.ebay.co.uk/itm/Genuine-BMW- ... Swl7pearYz
AlexD
Post by AlexD »
Jack Bauer wrote: Thu Sep 10, 2020 10:20 am If you do then please share the design.
They are good pumps and typically last ~100k miles, rebuild kits are readily available too. I had to rebuild the one on my M5, they get dirty inside. I will look into this thanks. I was not sure if there was a required pressure that had to be sustained.
mdrobnak
Post by mdrobnak »
Those seem to be a much more reasonable price - but some of them say SMG pump if searched for on the US site. Usually that is Pentosin CHF 11S that is flowing through that, I'm not sure if there would be any compatibility issues. But if so, $60 - 100 is better than another $700 just for a pump!
Someone needs to just give it a shot (won't be me sorry!).
For those interested in oil pressure here's one from the back catalog :
AlexD
Post by AlexD »
The viscosity of the fluids doesn't seem to be massively different from what I can tell.
My only consideration is the SMG Pump does not run continuously on the S85 V10, the SMG only uses pressure to actuate the clutch and shift gears
Ah, I thought what I linked to were engine oil pumps for the S85?
AlexD
Post by AlexD »
Jack Bauer wrote: Fri Sep 11, 2020 7:12 am Ah, I thought what I linked to were engine oil pumps for the S85?
You are absolutely right - my apologies, its one of the two scavenge pumps for the partial dry sump, at a glance it looked similar to SMG Motor. I will ask my friend who is breaking his S85 if he has a one for mates rates :D
EDIT: After checking RealOEM it looks like this pump is also used on the transmission to circulate the transmission fluid to the cooler, should be a good candidate on paper.
Mobert
Post by Mobert »
Oil pump flange on the transmission,
mdrobnak
Post by mdrobnak »
AlexD wrote: Fri Sep 11, 2020 7:49 am
Ah, hence my confusion as well. Good to see it is definitely flexible.
Good find, Damien. (and now we have another BMW part for BMW conversions :D)
-Matt
ggeter
Has thanked: 4 times
Been thanked: 28 times
Post by ggeter »
Have any of you published your 450h shift code? I see the parameters and setup in Damien's base, but wondering if any of you have forked it?
xp677 wrote: Fri Apr 03, 2020 10:29 am When writing code for this, don't forget to set your MG1 and MG2 torque to zero before the shift, and then ramp this back up (don't reapply it all instantly) once the shift is complete.
I'd recommend doing the shifts at around 5000rpm for MG1, so I'd try upshift at 6000 and downshift at 4000. Ratios are 1.9 and 3.9 so this will keep MG1 within 12000rpm.
If SP is purely a line pressure solenoid, then likely this can be ignored, and the pressure controlled with the oil pump speed instead. Or maybe a combination of the two for fine control.
It might be worth looking at what SP does during shifts, likely pressure will be momentarily increased during a shift. Maybe this is a use for SP. I noticed the oil pump controller is a bit slow to react to changing speeds.
Houston, Texas, USA
EV Newbie
IT Consultant
xp677
Post by xp677 »
As far as I'm aware, this code has not yet been written.
Gigas
Post by Gigas »
Just a curious question- but what foot pedal are people using with this gearbox and vcu
What was I doing?
steveknox
Has thanked: 23 times
Been thanked: 20 times
Post by steveknox »
I'm using an RX8 pedal, as I'm converting an rx8. They also happen to work well and are very cheap and readily available
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
Gigas
Post by Gigas »
steveknox wrote: Mon Nov 30, 2020 4:59 pm I'm using an RX8 pedal, as I'm converting an rx8. They also happen to work well and are very cheap and readily available
like this one?
https://www.ebay.com/itm/Mazda-RX-8-RX8 ... .l4275.c10
seems pretty good to me though i'd need to figure pinout
What was I doing?
steveknox
Post by steveknox »
That's the one! The pinout (front to back as you look at the pedal) is:
5v
Gnd
Ref 1
5v
Gnd
Ref 2
There are 2 reference signals, for redundancy.
Mazda RX-8
GS450h Running Gear
Outlander Charger
nkiernan
Has thanked: 516 times
Been thanked: 95 times
Post by nkiernan »
Gigas wrote: Mon Nov 30, 2020 4:32 pm Just a curious question- but what foot pedal are people using with this gearbox and vcu
Gigas,
Just got to run two gearboxes side by side today. Used a BMW pedal on one and a Ford Transit Connect pedal on the other. Transit worked with no mods to the code, but the BMW pedal needed some tweaking.
With the v3 code, the BMW pedal gave values of 98 to 1827 and the Ford pedal gave 0 to 1437. In the 'get_torque()' function in the code, the pedal values can be tuned to suit the pedal to get the full range.
I just added the line: SerialDEBUG.println(ThrotVal); in the void Loop() function and watched the serial monitor as I used the pedal to see that ranges they were giving out.
Tried to upload a photo for info but new to the forum and getting an attachment error, so have to figure that out later!
