I've been wrestling with erratic speed plotting with my inverter. I'm at a loss how to troubleshoot this issue. I have an encoder which is providing 64 ppr. In this case, I've run the inverter in manual mode by starting it with the button on the web interface.
I'm running the inverter with the following values. According to the documentation this should provide a speed of 10hz. What RPM should I expect when running the inverter manually with these parameters? My optical tachometer reads the motor shaft is turning approximately 2300 RPM and the speed plot in the web interface is all over the place.
fslipspnt 10
ampnom 70
Shaft RPM measured by optical tach:
Erratic inverter speed plot:
I have exported a copy of the parameters I used for this test run if they might be useful for diagnosis. I have the feeling I am making a simple mistake, but I just can't figure out problem. Any suggestions what I may need to correct?
