Tesla Charger Support Thread
Locked
nesto1972
Post by nesto1972 »
i know i know!
Can i ask if there is a software on the board or is it forbidden (only for developers)
and it means N O T !! Ok?
Kevin Sharpe
Been thanked: 9 times
Post by Kevin Sharpe »
nesto1972 wrote: Mon May 25, 2020 11:04 am Can i ask if there is a software on the board or is it forbidden (only for developers)
A few people are working on the V5 software in their spare time (here)... hopefully they will get it working but for now V2/V3/V4 hardware/software is the most widely deployed and tested.
nesto1972
Post by nesto1972 »
thank you for your information!
Kevin Sharpe
nesto1972 wrote: Mon May 25, 2020 11:44 am thank you for your information!
no problem... get yourself a local electronics engineer who can help you... comparing a working board to a faulty board will be easy for them :)
Has thanked: 75 times
Been thanked: 696 times
The boards are loaded with working software.
Kevin Sharpe
Jack Bauer wrote: Mon May 25, 2020 12:41 pm The boards are loaded with working software.
ok cool... is that the V5 software published on your GitHub in February?
Yes this is it here with the mods by Jon Volk and Tom. Working in Jon's car.
https://github.com/damienmaguire/Tesla- ... er_Gen2_V5
nesto1972
Post by nesto1972 »
Thats great,i was not sure if there is already a running software aviable.
I found this picture from the cable for the Serial monitor !
Is that right ? TLL-232R-3V3?
Regards
NESTO
Yep thats exactly what you need.
Video manual for building the Gen 3 charger controller kit :
Has thanked: 264 times
Been thanked: 717 times
bulletbug wrote: Sun May 24, 2020 10:06 pm I found a way to get 2 logs (serial and canbus) during the same timeframe. SavvyCan524.csvSerialLog524.rtf
Here are my settings:
Settings Menu
1 - Auto Enable : ON
2 - Modules Enabled : 123
3 - Can Mode : Off
4 - Port Type : 1
5 - Phase Wiring : 1
6 - DC Charge Voltage : 400V
7 - AC Current Limit : 11A
8 - CAN0 Speed : 500
9 - CAN1 Speed : 500
a - Can Debug : OFF
b - EVSE Debug : ON
t - termination voltage : 450V
q - To Quit Menu
So you are using a 120Vac supply? This has thrown up quite a few strange behaviours in the past.
Can you please just charge off one module (change enabled modules to 1, 2 or 3) then take a can capture and measure the current and voltage and provide these for further analysis.
nabilriaz
Post by nabilriaz »
Jack Bauer wrote: Mon May 25, 2020 2:30 pm Yes this is it here with the mods by Jon Volk and Tom. Working in Jon's car.
The link for the software is in Jon's Github account , or this link ?
I will never give up
bulletbug
Post by bulletbug »
tom91 wrote: Tue May 26, 2020 5:15 pm
I've done as you requested. Here is the status of these files.
1. Reverted to original copy of .ino file found here
https://github.com/damienmaguire/Tesla- ... rgerV4.ino
2. DC voltage reported on serial monitor as 518v. True pack voltage is 380v.
3. To fix this voltage reporting I modified scaler value on lines 822, 827 and 832 to cause dcvolt to display correct pack voltage on serial monitoring.
4. Other than that no other software changes are included in these results.
5. The EVSE (small portable charger unit from Chevy Spark) lists specs of 120v 60hz 12Amp
Thank you for your help.
SavvyCan526.csv
(632.97 KiB) Downloaded 346 times
Settings526.rtf
(699 Bytes) Downloaded 255 times
SerialLog526.rtf
(150.3 KiB) Downloaded 349 times
bulletbug wrote: Wed May 27, 2020 12:37 am
SavvyCan526.csvSettings526.rtfSerialLog526.rtf
What sort of current did you measure on the DC side?
bulletbug
Post by bulletbug »
tom91 wrote: Wed May 27, 2020 8:20 am
Measuring with a clamp meter on the most negative end of the battery pack the current is low enough that it can be confused with noise. It is displaying between 0.00 and 0.05 amps. In tests where I've used all 3 modules with similar settings the clamp meter would show 0.15 to 0.20.
My clamp displays 2 decimal points and I've confirmed it is accurate by comparing to a DC power supply with another amp meter. They match readings down into the .05 range.
I also have a 240v 42 amp split-single phase EVSE mounted in a different location. If it would help I could retrieve that and test it under the same settings. Anything you need me to do or try, I'm good with. Thank you so much for your help.
bulletbug wrote: Wed May 27, 2020 2:26 pm
Yes give the 240V EVSE a test, as there is some comms over about the AC voltage and there are module firmware limits based on AC inputs.
Bryson
Post by Bryson »
It looks like your problem might be on the AC side in software as your limit is 10A and the serial output is reporting >10A AC. If this is all calculated from DC, it seems wise to trace those calculations back. Has anyone ever gotten 120V single phase running here? It might be something silly like an overflow in a calculation somewhere when AC voltage is in the 120 range. Just a thought, I don’t have my board to start debugging yet but operating on both 120 and 240 automatically is a must for me too.
bulletbug
Post by bulletbug »
Bryson wrote: Wed May 27, 2020 5:00 pm It looks like your problem might be on the AC side in software as your limit is 10A and the serial output is reporting >10A AC. If this is all calculated from DC, it seems wise to trace those calculations back. Has anyone ever gotten 120V single phase running here? It might be something silly like an overflow in a calculation somewhere when AC voltage is in the 120 range. Just a thought, I don’t have my board to start debugging yet but operating on both 120 and 240 automatically is a must for me too.
I'm curious to hear if anyone else has successfully used 120v. I've taken new readings with the higher voltage charger and will post them next.
bulletbug
Post by bulletbug »
tom91 wrote: Wed May 27, 2020 3:36 pm
Ok. I've rerun logs using the higher voltage charger. The EVSE is a Juicebox brand with wifi reporting. Watching the related app I'm able to get what I consider to be more accurate charging stats, voltage, amps, etc. Update cycle for the app seems to be in the sub-second range since it reports the HZ of the AC line
Observed Amps: 0.8 amps stable
Initializes and moves directly to .8 amps and holds steady. I've rerun it several times, resetting the board, unplugging charger etc. and get the same results.
SavvyCan527.csv
(1.5 MiB) Downloaded 384 times
Settings527.rtf
(694 Bytes) Downloaded 348 times
SerialLog527.rtf
(278.51 KiB) Downloaded 312 times
Bryson
Post by Bryson »
Interesting that your AC current at both 120 and 240V bounces between either 10.67 or 19.20 amps. I’d start with the AC current calc and work backwards. If I’m understanding correctly, AC current is back-calculated from DC current?
bulletbug
Post by bulletbug »
Bryson wrote: Wed May 27, 2020 6:27 pm Interesting that your AC current at both 120 and 240V bounces between either 10.67 or 19.20 amps. I’d start with the AC current calc and work backwards. If I’m understanding correctly, AC current is back-calculated from DC current?
Something that's not shown in these logs is that I've seen AC current (Input side) showing at 2.13 amp when AC line is completely unplugged. I'll start looking at your suggestion. I'm looking forward to getting Toms feedback as well.
Thanks for the input.
Bryson
Post by Bryson »
May be a mathematical scaling issue due to some foul variable play. (19.2-10.67)/4 = 2.13
Round division numbers are always suspect :)
bulletbug wrote: Wed May 27, 2020 6:17 pm
SavvyCan527.csvSettings527.rtfSerialLog527.rtf
Please report on accurately I see you mention AC read outs from the Juice box.
So the Juicebox tells you the AC current correct, and this is 0.8 Amps is it not?
Can you please see what it draws when you set the AC limit setting to 10 instead of 5. I might be the stupid command formatting is changed.
Please also do not speculate how values are calculated as all displayed feedback values are purely translated from canbus there is no other math happening. So this looks like an exercises of rescaling/checking all values reported AND sent.
Bryson
Post by Bryson »
His prior log was at 10A. Happy to stay in my swim lane and not contribute. Carry on :)
Bryson wrote: Wed May 27, 2020 7:37 pm His prior log was at 10A. Happy to stay in my swim lane and not contribute. Carry on :)
Correct but he was not measuring AC current but DC current. We are needing to redo the scaling as I mentioned.
there literally is nothing calculated in the software accept the current limit and then translated onto can along with the voltage limit.
Software running on the logic board is alot dumber than you might think.
Locked
