Revision as of 17:08, 13 December 2025 by Davefiddes (talk | contribs) (→Parameter Reference: Add missing derate parameters with documentation from relevant forum threads)
Motor Parameters
Example: boost=1700
Inverter Parameters
Parameter Reference
set param <value>
to change it. Type
get param
to get the current value.
Motor (FOC)
exckp 0 20000 3000 Exciter controller gain (Renault Zoe variant only)
cogkp -1000 1000 0 Anti-cogging modulator gain. This generates a trapezoidal wave form to counter the cogging current of IPM motors.
cogph 0 65535 0 Anti-cogging modulator phase angle between cogging current and electrical rotor angle
cogmax 0 30000 0 Maximum amplitude of the anti-cogging current
fwcurmax A -1000 0 -100 Maximum field weakening current. Must be set to critical current of motor (TODO: link forum). Set to 0 for disabling field weakening
excurmax A 0 10 0 Exciter current maximum (Renault Zoe variant only)
Motor (sine)
Motor (common)
encmode 0 4 0 0=single channel encoder, 1=quadrature encoder,
dirmode 0 1 1 0=button (momentary pulse selects forward/reverse), 1=switch (forward or reverse signal must be constantly high)
Needs PWM restart
minpulse dig 0 4095 1000 Narrowest or widest pulse, all other mapped to full off or full on, respectively (Obsolete)
0001 = 1 Swap Currents ony
0010 = 2 Swap Resolver only
modmax dig 37000 45000 37836 Values over 37836 over-modulate the PWM sine wave. This can achieve a slightly higher AC voltage at the expense of greater motor losses. (only "FOC" software)
Derating
idcflt dig 0 11 9 Filter co-efficient applied to idc prior to derating. Increasing this makes the DC current derating smoother.
tmphsmax °C 50 150 85 Maximum permitted temperature of the inverter heatsink. As the temperature gets within 10°C of this limit the throttle will be scaled back by 10% for every degree until it hits the limit.
tmpmmax °C 70 300 300 Maximum permitted temperature of the motor. As the temperature gets within 10°C of this limit the throttle will be scaled back by 10% for every degree until it hits the limit.
accelmax rpm/10ms 1 1000 1000 Maximum permitted acceleration increase (traction control)
accelflt dig 1 5 3 Filter between the motor speed and the acceleration rate limiter. Higher values will smooth the input but will make the acceleration rate limiter react more slowly.
Charger
Throttle
Regen
maxregentravelhz Hz 0 1000 0
Automation
cruisethrotlim % 0 100 50 Throttle limit when cruise control is enabled
Contactor Control
udcsw V 0 1000 330 Voltage at which the DC contactor is allowed to close
outmode 0 2 0 0=DC switch output, 1=Motor temp controls the fan output, 2=Heatsink temp controls fan output
fanthresh °C 20 300 50 Temperature at which the fan output is turned on when outmode is 1 or 2
Auxillary PWM
Communication
controlid 1 2047 63 The CAN ID used for controlling the controlling the inverter via CAN
controlcheck 0 1 1 0=Check the counter field in canio CAN frames for legacy VCUs only, 1=Validate the 8-bit truncated STM32 CRC in the canio frame
Testing
Spot values
get
get il1,il2,udc
Name Unit Description
version Firmware version
hwver Hardware version
lasterr Last error message
udc V DC link voltage
uac V Calculated AC voltage
idc A Calculated DC current
il1 A AC current L1
il2 A AC current L2
il1rms A RMS current L1
il2rms A RMS current L2
ilmax A Calculated max of il1, il2, il3
boostcalc A DC link adjusted boost setting
fweakcalc A DC link adjusted fweak setting
fstat Hz Stator frequency
speed rpm Motor speed
pot dig Pot value, 4095=max
range:
dir Rotation direction. -1=REV, 0=Neutral, 1=FWD
tmphs °C Heatsink temperature
tmpm °C Motor temperature
din_forward Direction forward
Tuning Guide
