Revision as of 15:42, 13 December 2025 by Davefiddes (talk | contribs) (→Parameter Reference: minpulse would appear to have disappeared some time ago (before 2020))
Motor Parameters
Example: boost=1700
Inverter Parameters
Parameter Reference
set param <value>
to change it. Type
get param
to get the current value.
Motor (FOC)
exckp 0 20000 3000 Exciter controller gain (Renault Zoe variant only)
cogkp -1000 1000 0 Anti-cogging modulator gain. This generates a trapezoidal wave form to counter the cogging current of IPM motors.
cogph 0 65535 0 Anti-cogging modulator phase angle between cogging current and electrical rotor angle
cogmax 0 30000 0 Maximum amplitude of the anti-cogging current
fwcurmax A -1000 0 -100 Maximum field weakening current. Must be set to critical current of motor (TODO: link forum). Set to 0 for disabling field weakening
excurmax A 0 10 0 Exciter current maximum (Renault Zoe variant only)
Motor (sine)
Motor (common)
encmode 0 4 0 0=single channel encoder, 1=quadrature encoder,
dirmode 0 1 1 0=button (momentary pulse selects forward/reverse), 1=switch (forward or reverse signal must be constantly high)
Needs PWM restart
minpulse dig 0 4095 1000 Narrowest or widest pulse, all other mapped to full off or full on, respectively (Obsolete)
0001 = 1 Swap Currents ony
0010 = 2 Swap Resolver only
Derating
Charger
Throttle
Regen
maxregentravelhz Hz 0 1000 0
Automation
cruisethrotlim % 0 100 50 Throttle limit when cruise control is enabled
Contactor Control
udcsw V 0 1000 330 Voltage at which the DC contactor is allowed to close
outmode 0 2 0 0=DC switch output, 1=Motor temp controls the fan output, 2=Heatsink temp controls fan output
fanthresh °C 20 300 50 Temperature at which the fan output is turned on when outmode is 1 or 2
Auxillary PWM
Communication
controlid 1 2047 63 The CAN ID used for controlling the controlling the inverter via CAN
controlcheck 0 1 1 0=Check the counter field in canio CAN frames for legacy VCUs only, 1=Validate the 8-bit truncated STM32 CRC in the canio frame
Testing
Spot values
get
get il1,il2,udc
Name Unit Description
version Firmware version
hwver Hardware version
lasterr Last error message
udc V DC link voltage
uac V Calculated AC voltage
idc A Calculated DC current
il1 A AC current L1
il2 A AC current L2
il1rms A RMS current L1
il2rms A RMS current L2
ilmax A Calculated max of il1, il2, il3
boostcalc A DC link adjusted boost setting
fweakcalc A DC link adjusted fweak setting
fstat Hz Stator frequency
speed rpm Motor speed
pot dig Pot value, 4095=max
range:
dir Rotation direction. -1=REV, 0=Neutral, 1=FWD
tmphs °C Heatsink temperature
tmpm °C Motor temperature
din_forward Direction forward
Tuning Guide
