Content Management
Revision as of 08:11, 10 May 2025 by Powercontrol (talk | contribs) (initial commit)
DRAFT - DRAFT - DRAFT
the objective of this page is to explain how the content of the wiki page could be structured using Semantic for Mediawiki (SMW) to build a scalable and object-based wiki (for search and relation-building aspects) and still keeping the freedom for authors to create their content. There needs to be a trade-off to be found between freedom and structure.
Principles
SMW uses multiple notions. They are key to be used properly for good use.
Object Usage Naming Convention Example
Property defines a relation between 2 objects, or assign an attribute to an object UpperCamelCase.DestinationObjectType or UpperCamelCase.DestinationAttributeType FoundIn.Page
HasWeight.Qty
Template defines which properties shall be defined at the creation of an object. Not all pages must be created using templates, but objects which have relations between themselves are best created using templates. T/UpperCamelCase.OutputFormat T/Connector.Infobox
T/Battery.Table
Form A Form is an helper for the author to create a templated object. The form allows to create a consistent visual structure to pages F/UpperCamelCase - the Form refers to a corresponding Template, but the output format will not be referred to in the form name.
A form can also call mulitple templates
F/Connector
F/Battery
