LS600H
The LS600H drivetrain is very similar to the GS450H drivetrain, with a few key differences:
- Transmission
- AWD output via integrated transfer case
- Bellhousing bolt pattern
- Rear output flange bolt pattern
- Inverter
- Transmission to inverter HV wiring
- LV inverter pinout
- Access to HV bus bars in inverter
- Engine and transmission (Engine room) wire harnesses
The LS600H has an external oil cooler, and the pump motor is controlled by the same oil pump controller as the GS450H. The connectors used at inverter, resolver, shift switch and shift solenoids are identical to the GS450H. The input shaft spline is also identical. At time of writing, the LS600H appears to work with Zombieverter on the GS450H parameter settings as proven by a short test drive at very low speed.
