Volvo Electronic Throttle Pedal
Revision as of 09:28, 8 September 2024 by J0hannes (talk | contribs)
P80 Platform (850, V70 I, ...)
Electrical Connection
The part number of the 6 pin electrical connector 978151[1], the terminals and seals can be found on Skandix as well[2].
Pinout and Cable Colors (9447135, 9447136)
Pin Number Cable Color Function Comment Range
Idle Max Kickdown Max Comment
1 Gray Idle Switch 1.17kOhm Open Open Measured to Ground
2 Yellow Ground
3 Blue-Black (two stripes each) Kickdown Switch Automatic only Open Open 1.14kOhm Measured to Ground
4 Pink Upper Potentiometer Tap 2.23kOhm 1.63kOhm 1.48kOhm Measured to Center Tap
5 White Center Tap 1.15kOhm between 4 and 6
6 Brown Lower Potentiometer Tap 1.30kOhm 1.86kOhm 1.98kOhm Measured to Center Tap
Variants and Part Numbers
Throttle Pedal Variants
Part Number Gearbox LHD/RHD Vehicles Used Comments Confirmed
9447135 Manual LHD Diesel only (should be equal to 9447136)
9447136 Automatic LHD Diesel only yes
9447137 Manual RHD Diesel only (should be equal to 9447136)
9447138 Automatic RHD Diesel only (should be equal to 9447136)
P2 Platform (V70 II, S60 I, ...)
The P2 platform comes with Ride-by-Wire for all engines.
