Renault Kangoo 36
Revision as of 09:18, 1 February 2024 by Bigpie (talk | contribs) (Adding extra details)
The phase 2 Renault Kangoo 36kWh pack consists of 12 modules, roughly 16kg 14x21x31 cm each. The usable capacity is apparently 33kWh. It uses a centralised BMS, like the Nissan Leaf, as opposed to a distributed BMS with each module having it's own satellite board. So care must be taken to ensure the cell tap plugs are connected in to the modules in the correct order or the BMS may be damaged. Also note the cell taps will have potentially high voltage across them.
Contactor Box
The pack doesn't have a negative contactor, the only way to isolate it is to pull the service disconnect. In the contactor box there's a current sensor, pre-charge resistor, pre-charge relay, main contactor and a 275a 1000V fuse.
The main contactor is 150a rated.
Contactor box
Manual Service Disconnect socket
Mid Pack Fuse
There are 2 external Low voltage Connectors for the battery pack.
Grey Yazaki x
Pin Internal Wire Function
1 Black 12v BMS supply via 10a fuse
2 x
3 x
4 x
5 x
6 Yellow Can High
7 White 12v Contactor supply via 15a fuse
8 x
9 x
10 x
11 x
12 Blue Can Low
Black Yazaki 7283-8854-30
1 Black Ground
2 x
3 Green Main Contactor (ground to close)
4 x
5 Blue Pre-charge relay (ground to close)
BMS
