Renault Kangoo 36
The phase 2 Renault Kangoo 36kWh pack consists of 12 modules, roughly 16kg 14x21x31 cm each. The usable capacity is apparently 33kWh.
There are 2 external Low voltage Connectors
Grey Yazaki x
Pin | Internal Wire | Function |
1 | Black | 12v BMS supply via 10a fuse |
2 | x | |
3 | x | |
4 | x | |
5 | x | |
6 | Yellow | Can High |
7 | White | 12v Contactor supply via 15a fuse |
8 | x | |
9 | x | |
10 | x | |
11 | x | |
12 | Blue | Can Low |
Black Yazaki 7283-8854-30
1 | Black | Ground |
2 | x | |
3 | Green | Main Contactor (ground to close) |
4 | x | |
5 | Blue | Pre-charge relay (ground to close) |
