16-cell BMS
Communication
All configuration, queries and firmware updates are done via the CAN bus. There is no independent web interface like known from e.g. the inverter. However there is a solution to connect an ESP32 via CAN and then have the known web interface [1] or you can use Dave Fiddes "oic" tool for the command line[2]. It is important to know that the main module has node-id 3 and the subsequent ones 3+i (i index of submodule, so 1st submodule has node-id 4). The base node id can be configured to start at something else than 3.
Apart from that the modules output periodic CAN messages depending on their role.
All modules output on ID 500 (0x1F4) + i
| start | length | item | description |
| 0 | 16 | umin | minimum cell voltage of module i |
| 16 | 16 | umax | maximum cell voltage of module i |
| 32 | 16 | uavg | average cell voltage of module i |
| 48 | 8 | numchan | number of connected cells |
| 56 | 8 | temp | temperature reading of module i |
In addition the main module outputs on id 300 (0x12C)
| 0 | 10 | chargelim | maximum charge current in A |
| 10 | 10 | dischargelim | maximum discharge current in A |
| 20 | 10 | soc | Pack soc in 4*% |
| 40 | 12 | idcavg | Averaged current reading of last 1s |
| 52 | 10 | utotal | Total pack voltage in V |
Reading individual cell voltages
Cell voltages are only available via CAN SDO from the module that measures them. So voltages 1-16 must be queried from the first (main) module, 17-32 from the 2nd (1st submodule) and so on. With Dave Fiddes tool this translates to:
oic -n 3 dumpall #dumps all values including cell voltages from 1st module
oic -n 4 dumpall #same for second module
oic -n 4 read u0 #Read first cell voltage of second module
For querying voltages say in your arduino sketch you'll need to acquire every voltage separately by sending and receiving SDO messages
0x603#0x40 idhigh 0x21 idlow 0 0 0 0
0x603#0x40 0x07 0x21 0xD6 0 0 0 0
0x583#0x43 0x07 0x21 0xD6 0xD0 0xED 0x01 0
The next cell would be on 0x7D7 and the last on 0x7E5. The next 16 voltages are then queried from node id 0x604.
Configuration Parameters
There is currently a limited set of parameters which will be extended as the software grows.
| gain | uV/dig | 1 | 1000 | 586 | Scaling factor from ADC digits to mV |
| numchan | 1 | 16 | 16 | Number of cells connected to the module | |
| balance | 0 | 1 | 0 | Enable/Disable balancing function | |
| idlewait | s | 0 | 100000 | 60 | Number of seconds to wait after stop of current flow to measure unloaded cell voltage |
| nomcap | Ah | 0 | 1000 | 100 | Nominal capacity |
| idcgain | dig/A | -1000 | 1000 | 10 | Gain (or actually division factor) of current sensor |
| idcofs | dig | -4095 | 4095 | 0 | 0A offset |
| idcmode | 0 | 3 | 0 | Current sensor mode 0=Off, 1=Single Ended ADC, 2=Differential ADC, 3=ISA current shunt | |
| tempsns | -1 | 3 | -1 | Temperature sensor -1=Off, 0=JCurve, 1=KTY81, 2=PT1000, 3=LeafBMS | |
| pdobase | 0 | 2047 | 500 | base COB Id for cyclic messages. Main module uses pdobase, 1st submodule uses pdobase+1 and so on | |
| sdobase | 0 | 63 | 3 | base node ID for SDO queries. Main module uses sdobase, 1st submodule sdobase+1 and so on |
