Getting started with an IVT-S and Arduino Uno CAN bus shield
Revision as of 10:43, 14 June 2023 by Marcexec (talk | contribs)
First of all, set up your Arduino Uno and CAN bus shield.
Once the data is coming in over CAN, we can write a simple program to read the current value from the IVT-S.
There could be a lot of messages coming back on the CAN bus, so we specify a "mask" and "filter" for the CAN message IDs we are interested in. CAN bus message IDs are 11 bytes long, so we will specify a mask of 0x7ff (which is 11111111111 in binary). Using an MCP2515-based shield, we can set up to six different filter IDs. According to the Isabellenhütte IVT-S data sheet, the message ID of the "Current" reading from an IVT-S is 0x521, so we will specify that as the filter.
Testing current measurement with IVT-S
Once those parameters are set, the data should come in over CAN bus every 20ms at 1Mb/s.
Serial console output of measured current values on CAN bus
The tricky part is that the current measurement comes from the the IVT-S as a buffer of four byte values in big endian order. We have to re-assemble these bytes to get the numerical current value (in mA). Once that's done, we get nice, readable numerical values on the serial console.
Here's the code:
// IVT-S meter using CAN bus shield
// electric_dart 2020
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
unsigned char len = 0;
unsigned char buf[8];
void setup() {
    // Set your Serial Monitor to 115200 baud
    Serial.begin(115200);
    // Initialise the CAN bus
    while (CAN_OK != CAN.begin(CAN_1000KBPS)) {            // init can bus
        Serial.println("Failed to initialise CAN bus. Retrying...");
        delay(100);
    Serial.println("CAN bus initialised.");
        set receive mask
    CAN.init_Mask(0, 0, 0x7ff);                         // there are 2 masks in mcp2515, you need to set both of them
    CAN.init_Mask(1, 0, 0x7ff);                         // 0x7ff is '11111111111' in binary, so we are checking 11 of the CAN message ID bits
        set receive filter
    CAN.init_Filt(0, 0, 0x521);                          // there are 6 filters in mcp2515
    CAN.init_Filt(1, 0, 0x521);                          // 0x521 is the CAN message ID for IVT-S Current value
    CAN.init_Filt(2, 0, 0x521);
    CAN.init_Filt(3, 0, 0x521);
    CAN.init_Filt(4, 0, 0x521);
    CAN.init_Filt(5, 0, 0x521);
void loop() {
    if (CAN_MSGAVAIL == CAN.checkReceive()) {         // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned long canId = CAN.getCanId();
        if (canId == 0x521) {
          Serial.print("Data received from IVT_Msg_Result_I");
          Serial.print("\t");
          // Convert individual big endian byte values to actual reading
          long reading = (buf[2] << 24) | (buf[3] << 16) | (buf[4] << 8) | (buf[5]);
          Serial.println(reading);
    // Refresh every 250ms
    delay(250);
