VCU Comparison
Revision as of 12:26, 18 January 2023 by Celeron55 (talk | contribs)
Caption text
Comparison ZombieVerter GEVCU7 Mini-E-VCU iPDM56v1.1
Open source software Yes Yes Yes Yes
Open source hardware Yes No Yes No
Schematics and board layouts available Yes No Yes Yes
Price (roughly inc. VAT + shipping + enclosure) 350€ 1500€ 135€
In Stock Yes Yes 2023-02
External connector pins 56 ? ? 56
External connector pin size (A) 5A? ? ? 5A?
Primary use case Inverter control including Toyota CAN inverter control, logging Outlander inverter Power distribution, I/O extension
Software platform libopeninv Arduino Arduino Arduino
External configuration interface Wifi Bluetooth, Wifi, USB serial ? USB serial, TTL serial
Configuration format Parameter list ? Arduino sketch Arduino sketch
Out-of-the box supported inverter brands OpenInverter, Nissan, Toyota, Lexus, Outlander? DMOC, CODA, Brusa, PM100, C300 Outlander None
MCU family STM32F1 iMXRT1062 ? AVR
Flash ? 16MB ? 32kB
RAM ? 1024kB ? 2kB
Supply voltage range 8...16V
Standby mode description 6mA running Arduino sketch at slow clock speed
Buses 3x CAN, 1x Toyota, 1x LIN, 1x RS232? 3x CAN ? 2x CAN
Number of inputs 10? 12 ? 14
Analog inputs (including throttle and external NTC channels) 6? 8 ? 5
PWM inputs 2
Additional special inputs ? ? ? 12V battery voltage monitoring
Signal PWM outputs 1? 0
Power PWM outputs (low / high side, A) 3x L ?A 4x L 3A
VCU Comparison draft by celeron55 (move this stuff to the table):
- Low-side power outputs, total A / count:
   - ipdm: 20A / 10x
   - zombie: 5A (limited by ground pin) / 9x?
   - gevcu7: 16A / 8x
- High-side power outputs, total A / count
   - ipdm: 15A / 10x
- Analog outputs:
   - ipdm: 2x 0-500mA low side slow
   - zombie: 2x AC coupled, 2x digital resistors
- Power outputs readable as inputs:
   - ipdm: 8
- Simultaneous customizable jumpers/resistors:
   - ipdm: 32
   - zombie: 0?
TODO:
- Add johu's vcu - Add other VCUs that have been used by people on the openinverter forums - Fill in missing info - Add links
