VAG MLBevo MQB Chargers
MEB Chargers
There are many different variants of MEB chargers with a wide range of potential power outputs.
3.6kW: 5QE915685 and 5QE915682
11kW and 22kW: - 5QE915684J, 5QE915684AD, 5QE915684A - From Audi e-Tron, single AC input, coolant connections at opposite end to electrical connections -
5QE915684BJ - I think it's from the Audi e-Tron, single AC input, coolant connections on the right side when looking from the connector end -
5QE915684BC, 5QE915684BK - From Porsche Taycan, dual AC input, coolant connections on the right side when looking from the connector end
Pinouts
Pin | Function |
1 | Terminal 30 (permanent 12V) |
2 | |
3 | |
4 | Charge Port RGB LED +12v o/p |
5 | Charge Port RGB LED +12v o/p |
6 | |
7 | |
8 | |
9 | Powertrain CAN bus, high |
10 | Powertrain CAN bus, low |
11 | Hybrid CAN bus, high |
12 | Hybrid CAN bus, low |
13 | HVIL IN |
14 | |
15 | HVIL OUT |
16 | Lock drive +. Drive to 12v to close lock. |
17 | Lock Drive – Drive to 12v to open lock |
18 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. |
19 | Lock feedback. 1K fully locked ur unlocked. 11K in travel. |
20 | |
21 | Immediate charge buttons |
22 | Charge Port RGB LED +12v o/p |
23 | Control Pilot (CP) |
24 | Plug Present (PP) |
25 | Immediate charge buttons |
26 | |
27 | Temperature sender for charging socket. 1067R at approx 15C |
28 | Temperature sender for charging socket. 1067R at approx 15C |
29 | |
30 | |
31 | Charge port door lock actuator |
32 | Charge port door lock actuator |
33 | Charge port door lock actuator |
34 | Charge port door lock actuator |
35 | |
36 | |
37 | |
38 | |
39 | |
40 | |
41 | |
42 | |
43 | |
44 | |
45 | |
46 | |
47 | |
48 | |
49 | |
50 | |
51 | Immediate charge buttons |
52 | |
53 | |
54 | |
55 | |
56 | |
57 | |
58 | |
59 | |
60 | Terminal 31 (Ground) |
