Toyota Prius Gen2 Board
The Toyota Prius Gen2 Board is an open source project to repurpose 2004-2009 Toyota Prius inverters for DIY EV use. It consists of a circuit board and programming that replaces the Prius' original ECU.
Prius Inverter
The Toyota Prius is a hybrid vehicle. Their inverts are suitable and attractive for DIY EVs because of:
- Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
- 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control.
Pin Header Summary
Control Board Description:
Pin | Name |
TB1-1 | 12v-in (Do I supply this or is this created by the HV Battery connecting to the inverter, which then creates 12v from its DC-DC converter?) |
TB1-2 | GND (All GNDs in common? Chassis GND or HV battery Neg?) |
TB1-3 | 5v VCC (Looks like this is created by this board, from the 12v in. Does it wire to the inverter?) |
TB1-4 | Throttle In (Added by me with a pedal? If so what's expected? Also connected to inverter or not?) |
TB1-5 | Regen In (Ditto with throttle same questions) |
TB1-6
GND | |
TB1-7 | Brake In (Ditto with throttle) |
TB1-8 | Start In (Ditto with throttle) |
TB1-9 | For In (Forward input? Just a signal? Ditto with throttle) |
TB1-10 | Rev In (Reverse input? Ditto with throttle) |
TB3-1 | |
TB3-2 | GND |
TB3-3 | Phase U (PWM signals for that phase that create the waveform that the inverter then boosts to motor-size voltages and currents?) |
TB3-4 | Phase Y |
TB3-5 | Phase W |
TB3-6 | Current U |
TB3-7 | Current Y |
TB3-8 | MG2 Enable |
TB3-9 | MG2 Fault |
TB3-10 | DC Bus |
TB2-1 | |
TB2-2 | ENCA In (Encoder inputs?) |
TB3-3 | ENCB In |
TB3-4 | GND |
TB3-5 | HS Temp |
TB3-6 | MOT Temp |
TB4-1 | GND |
TB4-2 | Main Con |
TB4-3 | PRecharge |
TB4-4 | |
TB4-5 | CAN L |
TB4-6 | CAN H |
32-pin Prius Inverter Pinout:
Pin # | Designation | Wire Color | Description |
Example | Example | Example | Example |
