Audi A2 Conversion
Revision as of 18:58, 6 February 2022 by Geduxaz (talk | contribs) (ECU)
On this page we describe the conversion of an Audi A2 1.4i petrol to electric propulsion. We will use the following components:
  • Nissan Leaf 24 kWh battery pack with original BMS
  • Toyota Prius Gen 2 (2004-2009) transaxle with matching inverter
  • openinverter Prius Gen2 motor controller
  • openinverter main board running stm32-car (VCU in ECU enclosure)
Pin mapping
We start out by mapping out useful pins of the original wire harness
ECU
The ECU has two connector slots, a smaller one with pins 82-121 and a larger one with pins 1-81. Here we map out pins useful to us VAG wire color codes:
ECU pinout 1.4i (AUA, BBY)
# orig function our function wire color
1,2 GND
3 permanent 12V ro
4 ignition 12V
28 From generator (maybe DF) li/bl
65 Fuel pump relay- control ro/br
