Mitsubishi Outlander Water Heater
Revision as of 16:54, 3 November 2021 by Bigpie (talk | contribs)
The Outlander PHEV has an optional electric water heater. This unit appears to be a 3rd generation http://www.mhi.co.jp/technology/review/pdf/e542/e542057.pdf. Specified as a 4kw unit.
The photo below is a Gen 3 heater and is CAN controlled. Previous generations use an external ECU, currently nothing is known about these.
Low Voltage Pinout (Gen 3)
Top row, yellow is 12+, black is GND.
Bottom row, under the yellow is Can H and under GND is Can L
The mating connector looks to be Sumitomo 6189-0126 https://www.auto-click.co.uk/6189-0126?search=90980-10942
High Voltage Pinout
Can Messages from Heater (Gen 3)
When 12v is connected, without HV, the following messages are broadcast:
0x398 ID 00 09 00 3B 3B 00 00 00 at 100ms byte 3 seems to be water temperature, byte 4 device temperature
0x630 ID 00 00 00 00 00 00 00 00 at 500ms
0x398 ID 00 00 00 3B 3B 00 00 00 at 100ms
Control Can Messages
Not yet discovered.
