VW Hybrid Battery Packs
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
Golf GTE
BMS
Battery Modules
Passat GTE
Golf GTE
Cooling
Contactors/Pre-Charge
Passat GTE
The Control box contains
- PEC 300A 450VDC fuse
- 1 x Contactor Control Board
| Control board Interface Connector | |
The pinout is as follows:
| Pin | Function | Wire Colour | Notes |
| 1 | Green | ||
| 2 | Green | ||
| 3 | |||
| 4 | Black/Grey | ||
| 5 | |||
| 6 | Brown | ||
| 7 | |||
| 8 | GND | Brown/Red | |
| 9 | GND | Brown/Red | |
| 10 | +12V | Red | |
| 11 | |||
| 12 | |||
| 13 | |||
| 14 | CANH | Orange/Blue | 120 OHM |
| 15 | CANL | Orange/Brown | 120 OHM |
| 16 | +12V | Yellow | |
| 17 | |||
| 18 | GND | Brown/Red |
Can output ...
| CAN ID | Function | Notes |
| 000000BB | Shunt, Bytes 1 & 2 (16bit signed integer) | Multiply by 0.00625 to get amps |
| 18FED007 | ||
| 0000015B | ||
| 18FED008 | ||
| 18FED009 | Bytes 0 & 1 (16bit integer) | Possible Candidate Voltage @ Fuse |
| 18FED00A | ||
| 18FED003 | ||
| 18FED004 | ||
| 1A55545F | ||
| 16A95419 | ||
| 18FED006 | ||
| 18FED002 | ||
| 18FED005 |
Golf GTE
The control box contains a
- PEC 250A 450VDC fuse
- Current shunt.
| Pin | Function | Wire Colour | Additional |
| 1 | Connects to battery case | Black | Ring terminal on the end, maybe for isolation test? |
| 2 | Gnd | Black | |
| 3 | N/C | ||
| 4 | CAN H | White | 125ohm resistance between them. IC501 - TJA1042 |
| 5 | CAN L | Black | |
| 6-9 | N/C | ||
| 10 | 12v | Red | |
| 11 | 12v | Red | Likely 12V input. When supplied, IC204 begins outputting 5V |
| 12 | White | ||
| 13 | N/C | ||
| 14 | White | ||
| 15-19 | N/C | ||
| 20 | Pre charge relay switched gnd | Black | Q409 is responsible for switching this to ground. |
| 21 | Contactor switched gnd | Black | |
| 22 | Contactor switched gnd | Black | |
| 23 | 12v for precharge relay | Yellow | Isolated from 12v supply |
| 24 | 12v for contactor | Blue | Isolated from 12v supply |
| 25 | 12v for contactor | Red | Isolated from 12v supply |
| 26 | N/C |
2 x V216HC4 unknown
When the control board is powered up it emits a can message "f1 9 de ad"
Using Multiple Packs
